Which subwoofers for sound installation |
Post Reply | Page <12 |
sonic_traveler
Registered User Joined: 14 May 2022 Status: Offline Points: 11 |
This video is super helpful thanks ! I will check out some rental companies indeed to check these transducers out. At the beginning I was also thinking of using them but was afraid they wouldn't create a similar vibration in the body, because you probably recognize that it's coming from the floor. But I guess testing them would make things more clear. And if I can eliminate all these problems with that I would already be a big step further with my project ;). May I ask what is it that you are doing when you say sound career? And yeah, probably you are right^^. I don't want people getting heart attacks!
sonic_traveler
Hi there, thanks for the comment ;). Yes, I agree. I will definately go for rental now! I have to say, I do not completely understand what you are saying here -> "However If you can keep all the signals separate the result is far more chaotic and natural". Do you mean that if I would have each individual signal displayed on an individual speaker, this would work? Or that this would cause problems? Because, how I understood it, is that both will be problematic. Also, you are saying that a subwoofer is not made to display several signals at the same time, but a full range speaker would, as they are build to play several frequencies / harmonies? So you mean full range speakers would actually be better?
Edited by sonic_traveler - 15 May 2022 at 12:47pm |
sonic_traveler
Hi, thanks for your tips :). The site you mentioned is very helpful as well!
Tinnitus Rex
Registered User Joined: 31 October 2020 Status: Offline Points: 274 |
Ah, my career? ... errm..erm.. ,I make dreamers louder.If I can't make them sound good ..I can make them sound better. I just do this until I get a sensible job that doesnt hurt so much.
"couldn't we just like... use headphones?"
sonic_traveler
Thank you all! I think I have learned a lot already. I think now I have to process all the comments and tips ;). Feel free to keep on commenting. I might not answer directly!
sonic_traveler
haha okay
sonic_traveler
Lucasdude
My thoughts on this:- Using optical pulse sensors, mounted for the index finger of each chair shouldn't cause any feed back issues. These are probably fairly easy to source cheaply with a bit of digging. I remember some phones had them paired with the camera flash for this purpose. Specific bandpass cheap Chinese subwoofers are readily available and can be sold on after the event. I'm thinking something like a 15" dual reflex bandpass, 400-500w passive. Funnily enough, the design that greets you on the forum home page! Mount a cheap vibrating cushion or backrest to each chair in tandem with a dedicated subwoofe in front. So your example would be 5 of each. Bass at the frequencies you're talking about is essentially omni directional, so to keep things simple just have one signal per seat/sub. 5 channels of amplification is not expensive these day. Probably 2x 4 channel commercial amps from Crown or Cloud would do it and provide a few spare channels. A visual cue, probably connected somehow to the signal sense of the amplifiers would provide another dimension. This could be displayed as a heart beat graphic on a small monitor attached to the top hat pole above each subwoofer. As already mentioned, multiple heart beats will either accentuate each other if exactly in phase between subs, or cancel each other out if not. This compounding cacophony may or may not be what youre after! In the space you have described, which I imagine to be free space within an exhibition hall or similar will have no effective boundaries to reduce sounds leakage. This may get tiresome for your neighbours! Just my noggin outpourings, opinions are just like some other things!
Edited by Lucasdude - 15 May 2022 at 3:00pm |
