  New Posts New Posts RSS Feed - Void Infinite 8 mk2 - 2ohm stable?
tomrotten View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomrotten Quote  Post ReplyReply Direct Link To This Post Topic: Void Infinite 8 mk2 - 2ohm stable?
    Posted: 19 May 2022 at 7:51am
morning folk
anyone had hands on experience running these at 2ohm?
plan to run 8x void loaded 1850s
cheers
rotten noise soundsystem
1850s - A.S.S - FFA
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2022 at 8:34am
Originally posted by tomrotten tomrotten wrote:
morning folk
cheers
I would have no reservation, using amp with 2x 4 ohm drivers per channel.
I personally, would prefer 9001 or K20, or 2x other amps, to power 8x drivers.
But then most hornloaded cabs, with 8 ohm drivers are more like 12 ohms.
So you are not actually dealing with 2 ohm stereo.
Would personally suggest 2x Void Inf8 mk2, to properly drive 8x Voids.
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2022 at 9:22am
Also remember, Void Inf8Mk2 is rated at 3.6k per channel at 2 ohms.
Void V18-1000s are rated 1000W.
So even if 4x cabs per side were actually  2 ohms,  you still fall way short of fully powering drivers, which would  typically require 1.5x the power rating of your drivers.
Do yourself a favour, to preserve life  of amp and drivers, get 2x amps.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Earplug Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2022 at 10:16am
"Do yourself a favour, to preserve life  of amp and drivers, get 2x amps."
100% behind that. I really don't understand why people insist on over-stressing their amps. It makes no sense.
And besides anything else, one day the amp is going to say enough is enough and fail. If you have 2, you will at least be able to save the gig & carry on. Rely just on 1 and you invite disaster.
cravings View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2022 at 10:35am
agree. nice to know an amp will do the 4 drivers in an emergency, but i don't think it's a long term plan.
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2022 at 11:35am
Have always said, why buy big man, high powered drivers, only to under power them, or even worse, clip them to death, with amp, not strong enough, for the task.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomrotten Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2022 at 12:22pm
Cheers for the responses, confirmed what I needed to know having been told conflicting things
Good to hear that  it will do it if things get drastic tho
Now to find another...
Nice one Wink
1850s - A.S.S - FFA
Post Options Post Options   Thanks (0) Thanks(0)   Quote Earplug Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2022 at 1:12pm
Yup. I remember working one gig a few years ago where all the bass rested on one 10k amp. Amp went pop in the soundcheck & the crew had to scramble like f**k to replace. It was touch & go.  Ouch
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2022 at 2:18pm
That feeling, when the sub disappears... Dead
knet94 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote knet94 Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2022 at 5:00pm
Have ran 8 x PD1850s on a single Infinite 8 Mk2 on a few occasions in the past. No issues whatsoever.
This page was generated in 0.234 seconds.
