  New Posts New Posts RSS Feed - Amplifiers Rescue Gods
 Post Reply Post Reply Page  <12345 71>
Post Options Post Options   Thanks (0) Thanks(0)   Quote Earplug Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2022 at 11:32am
The Inkel looks nice Earplug, that's not a brand we ever had here in UK. Looks about 1977-78-ish? About 80w p/ch into 8ohms?
Yes - that's about right. I've seen Inkel stuff here go for silly prices. They do have a good reputation among the local hifi buffs.   Smile
EmPro View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EmPro Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2022 at 11:34am
And here is a case of a Matrix UKP1000 removed from Titanic and sold on ebay as faulty due to overheating issues...dunno why LOLLOL
Ater 2kg of dirt removed,and a new case...the amp is up and runnig as new Smile
Edited by EmPro - 28 May 2022 at 11:59am
EmPro Audio
Post Options Post Options   Thanks (0) Thanks(0)   Quote EmPro Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2022 at 11:52am
Originally posted by M4trix M4trix wrote:
I must admit I have never seen a genuine Motorola MJ15003 with such markings printed at 45° and such font, especially without made in Mexico. If seen on ebay nowadays I would definitely think they're fake. Back in the 80's in miserable ex Yugoslavia, these transistors were hard to come by. The most powerful transistors on Yugo-communist-disaster market was a dodgy 2N3773 and manufactured by EI Nish. Motorola MJ15003/MJ15004 were in my wet dreams. Thank God those days are history. LOL
There not fake mate,this are proper MJ15003,i wish i could find more of these...trust me i tryed to kill a pair of those in heavy load with no succes :) so i trust these Motorola MJ15003 with all my heart,on top of that Cloud fitted these outputs on there PA stuff.
Edited by EmPro - 28 May 2022 at 12:00pm
EmPro Audio
Post Options Post Options   Thanks (0) Thanks(0)   Quote EmPro Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2022 at 11:58am
By all means old...i cleaned them to look good LOLLOL
EmPro Audio
Post Options Post Options   Thanks (0) Thanks(0)   Quote EmPro Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2022 at 12:11pm
Here we have Vermona Regent 2023 with Tesla KD503 on outputs 2 each ch for i think 100w rms/ch these ,,things'' are loud as hell....as a fault the vu-meters didn't work (some ground wire was reduced to ash somehow) now is fully working with all the parts original from...1980 maybe?!? i did resoldered all the driver boards and changed the thermal paste on the KD503-s just to avoid further problems.Btw....it has dc speaker protection with relays on both ch :D
Edited by EmPro - 30 May 2022 at 3:49pm
EmPro Audio
Post Options Post Options   Thanks (0) Thanks(0)   Quote EmPro Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2022 at 12:36pm
Soundcraft Powerstation 600 i currently own 2 of these and one 1200,this one in the photos was loosing power at high volumes in 4R loads,so the main supply capacitors 6 of them needed to be replaced so i fitted 6x10.000uf/80v samwha capacitos,increasing a lot the power reserve with no side effects as the rectifier bridge can take the inrush current at start up,now the mixer is acting perfect with a lot of power reserve if needed Wink
Edited by EmPro - 28 May 2022 at 12:36pm
EmPro Audio
Post Options Post Options   Thanks (0) Thanks(0)   Quote EmPro Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2022 at 1:05pm
TSR 150X,nice little 1U amps with eq and mic function build in,V-FET toshiba outputs 2 per ch 2x75w rms 8r loads (only) i have three of them Smile all of them needed to be resoldered etc and put back together,no other internal faults founded:
Edited by EmPro - 28 May 2022 at 1:08pm
EmPro Audio
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbl_man Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2022 at 1:19pm
^These have cropped up before. TSR was something to do with Bass-Charrington/ Tobysound, they were installed in almost every pub in the UK in the late 80's. From memory, it even has a mic pre-amp in there too, for pub PA.
Post Options Post Options   Thanks (0) Thanks(0)   Quote EmPro Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2022 at 1:21pm
Indeed they have :D
EmPro Audio
Post Options Post Options   Thanks (0) Thanks(0)   Quote EmPro Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2022 at 1:38pm
Sorry about the quality of the pictures,just ss from an old video,the ideea comes when (as usual for the BK MXF range) the TIP-X vu-meter power stabilizer blows up and smoked the Vu-meters to deathLOL
BK MXF 400
Looks amazing in my home desk Big smile
I also added relay dc speaker protect...for no reason LOLLOL
Edited by EmPro - 02 July 2022 at 1:44pm
EmPro Audio
Post Options Post Options   Thanks (0) Thanks(0)   Quote EmPro Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2022 at 2:14pm
Jbsystems AX200 nice little 1U toy with toshiba 2SC5200/2SA1943 on outputs,i like the way they build these ones,just some loose connections in the psu side and up and running:
EmPro Audio
Post Options Post Options   Thanks (0) Thanks(0)   Quote EmPro Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2022 at 2:46pm
Citronic Conquest C12 (V12) same amps by all means,this one faulty on ch1,2 blown BUZ outputs and shorted BTA12 (the 12amps  triac from crowbar protection),remember that these series have smd driver boards that tends to suicide and almost impossibile to repair Cry also the output devices are a mix of single and dual die lateral mosfets...not something i like to much....
Edited by EmPro - 28 May 2022 at 2:47pm
EmPro Audio
