  New Posts New Posts RSS Feed - Amcron MacroTechs
Amcron MacroTechs
vinro View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote vinro Quote  Post ReplyReply Direct Link To This Post Topic: Amcron MacroTechs
    Posted: 05 June 2022 at 9:09pm
Question regarding Amcron MacroTech amps.
Colleague wants to mic, amp and sub his bass drum..
He has one HZ SB600 as a sub..also mics (Shure and AKG D112)
I was going to lend him one of my old Bose 1800's (series ones) but
looking at the SB600 the two coil inputs if both used present 4ohms..
and the old Bose, when bridged, must see 8 ohms..
So.. looking at Crown user sheets it would appear that the MacroTechs (601,1201 and 2401) can, when bridged, drive into 4 ohm with no problems..
So, question one ..is this correct ?
(when bridged they can drive into 4 ohms all evening ?)
Does any have any more info on the HZ SB600 ?
(reaching out to djeddie here as, looking through older posts,
he seems to know a fair bit about them..
And, lastly, does anyone know of a nice MacroTech anywhere ?
Not so keen on e-bay..colleague missed two..
but I suggested he holds off impulse purchases until I find out about bridge mode into 4 ohms..
Why Crown/Amcron..I used them back in the day and they never
gave out or caused problems (mind these were the much older DC150's)
so just have a soft spot for them..happy to be advised otherwise..
all best
Nick
Post Options Post Options   Thanks (0) Thanks(0)   Quote Elliot Thompson Quote  Post ReplyReply Direct Link To This Post Posted: 05 June 2022 at 10:00pm
Yes. The Crown Macro-tech (and the Micro-tech) can drive 4 ohms Bridged Mono all day with no issues providing you feed them enough current. They can also drive 1 ohm loads, Parallel-Mono configured.
Best Regards,
knet94 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote knet94 Quote  Post ReplyReply Direct Link To This Post Posted: 06 June 2022 at 2:15pm
I've got a MA1202 and a MA2400 that I'm looking to move on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote vinro Quote  Post ReplyReply Direct Link To This Post Posted: 06 June 2022 at 2:22pm
knet94
as I am but an egg crocwise it appears I cannot PM ?
How can I contact ?
I did think my e-mail was in my profile ..
best
nick
Post Options Post Options   Thanks (0) Thanks(0)   Quote knet94 Quote  Post ReplyReply Direct Link To This Post Posted: 06 June 2022 at 4:17pm
Originally posted by vinro vinro wrote:
knet94
How can I contact ?
best
nick
I've sent you an e-mail. I didn't even know that feature I used existed. However if that didn't work you can get me on o7557 o9o225.
BJtheDJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BJtheDJ Quote  Post ReplyReply Direct Link To This Post Posted: 06 June 2022 at 4:45pm
knet94
How can I contact ?
best
nick
You need to have accumulated at least 10 poiunts before you can send PMs
or post pictures, in fact most things except read and reply Big smile
then you know that you're not a Millenial kid.
</f
