Is it nessicary to seal drivers with gasket tape? |
sarsen1
Registered User Joined: 01 January 2016 Location: Bristol Status: Offline Points: 114 |
Posted: 07 July 2022 at 11:23am |
Is it best to seal a driver to the baffle with gasket tape or similar or are people just mounting the drivers directly most of the time?
doller
Young Croc Joined: 19 July 2014 Location: japan Status: Offline Points: 509 |
I think that it is good practice. I do it. Costs very little. You can sometimes hear air escaping from around the driver. Badly sealed boxes will mess with your x max. As always could be wrong.
sarsen1
That make sense, thanks!
1ManSoundsystem
Registered User Joined: 25 March 2019 Status: Offline Points: 48 |
hi, just a short hint from myself. ive seen people put the sealingtape on the speakergrill instead on the cabinet. dont do that. these speaker sealing tapes have very strong adhesive thats very hard to remove from the speaker, really nasty. rather put in on the wood of the box the speaker will be placed in.
teeth
what about handles, speakon dishes, hardware etc. is it good to use gasket sealing tape such as this to seal them in?
cardiffdon
Registered User Joined: 04 December 2008 Location: NewPort. Status: Offline Points: 482 |
yes
cardiffdon
make sure you get a good seal around that shit dude.
teeth
cheers cardiffdon... anything i should go for in particular? silicon or somethin? i'll grab that foam gasket shit otherwise. thanks again
cardiffdon
foam gasket stuff works fine for me.
cheers |
