Modifying generator |
hectorberman
Registered User Joined: 25 May 2017 Status: Offline Points: 78 |
Posted: 03 September 2022 at 9:27am |
Hi guys,
I've recently acquired a small diesel generator for smaller events. The generator in question has 2x16a out. I'm wondering if it is in anyway possible to change this to a single 32a socket? (I would be asking a qualified electrician to make the modification for me if it is possible)
GAZ.
What are the specs of the generator? It may not be big enough to provide a 32a supply.
100% Earth Moving Bass
monkeypuzzle
Young Croc Joined: 25 January 2005 Status: Offline Points: 923 |
As long as it was done safely and had the correctly rated breaker/wiring on it this would be fine. So if it’s a 5kva set then something like a 20a would be the one. Your sparky friend would be able to calculate the correct value to stop it being overloaded.
Edited by monkeypuzzle - 03 September 2022 at 10:56am |
hectorberman
It's a pramac p4500, supposed 3.7kw.
Is this a pointless endeavour?
csg
3.7Kw @230v is roughly what you can safely pull from one of the 16A connectors. If you already have 32A cable and distro by all means make a step up adapter from 16 to 32A to take advantage of the larger cable
hectorberman
That's exactly my situation. Much easier solution. Thank you!
