  New Posts New Posts RSS Feed - A&H Xone 43
A&H Xone 43
king david View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote king david Quote  Post ReplyReply Direct Link To This Post Topic: A&H Xone 43
    Posted: 25 November 2022 at 9:41am
I have an Xone 43 mixer and i dont really undersrand why if you put an external effect, when you engage It, the volume of the Channel that Is effected goes down....i Just think It doesnt make sense
dj jammin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dj jammin Quote  Post ReplyReply Direct Link To This Post Posted: 25 November 2022 at 2:36pm
That does seem a bit pointless.. what external effects unit are you using? Just thinking, if it's a send/return situation it should not affect volume of channel unless you are set at 100% effect and the output of the external unit is very low? Presume that's what you mean?
Reverence Sound system
Post Options Post Options   Thanks (0) Thanks(0)   Quote kedwardsleisure Quote  Post ReplyReply Direct Link To This Post Posted: 25 November 2022 at 3:01pm
Might it be an unbalanced>balanced problem? What does the fx unit have as i/o?
North Staffordshire
Post Options Post Options   Thanks (0) Thanks(0)   Quote king david Quote  Post ReplyReply Direct Link To This Post Posted: 25 November 2022 at 4:06pm
Benidub Digital delay with jack i/o
Post Options Post Options   Thanks (0) Thanks(0)   Quote king david Quote  Post ReplyReply Direct Link To This Post Posted: 25 November 2022 at 4:54pm
From the guide
Use this control to vary the amount of channel signal
that is sent to an external effects device connected to
the X:FX send / return on the rear panel. With this
control set to ‘dry’, none of the signal is routed to the
external effects loop. With the control in the central
position, half of the signal is sent to external effects,
while the other half is unaffected or, if filter is selected,
only the dry part of signal is filtered. With the control
set to fully ‘wet’, all of the signal is sent to external ef￾fects and the VCF filter is bypassed
Post Options Post Options   Thanks (0) Thanks(0)   Quote king david Quote  Post ReplyReply Direct Link To This Post Posted: 25 November 2022 at 5:01pm
Theres a volume drop when i move clockwise from dry to wet even with no effect linked in....
Post Options Post Options   Thanks (0) Thanks(0)   Quote dj jammin Quote  Post ReplyReply Direct Link To This Post Posted: 25 November 2022 at 9:29pm
That would make sense as more of the signal goes from direct to the send.. possibly you might find you need to boost the output of your delay unit..  also I'm assuming the dj mixer expects stereo send and return? Guess the benidub is mono? This could be an issue as well..
Post Options Post Options   Thanks (0) Thanks(0)   Quote kedwardsleisure Quote  Post ReplyReply Direct Link To This Post Posted: 26 November 2022 at 2:56pm
I've never heard of a benidub but googling it shows it's mono? How are you routing the stereo send & returns to it?
North Staffordshire
Post Options Post Options   Thanks (0) Thanks(0)   Quote king david Quote  Post ReplyReply Direct Link To This Post Posted: 26 November 2022 at 8:43pm
The Xone has rca connections so i am using adaptors to the jack i/o of benidub
But the Channel volume goes down when you move the FX Channel even with no FX linked in...
BigSoundNorthWest View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BigSoundNorthWest Quote  Post ReplyReply Direct Link To This Post Posted: 26 November 2022 at 9:17pm
Noticed this too, tonight on the same model mixer at a dance. .
Was solved by raising the output on the echo pedal, but still, it's a feature of this mixer it seems, not a fault
