Connecting DSP to Amplifiers & Surge/Power Advice |
Post Reply | Page <123 |
Conanski
Search for "rack mount screws" they have a nylon(plastic} washer with them that prevents scratching the equipment.
You should also run a tap through the holes in your rack to measure it's size, this will also clean out any dirt or paint that has accumulated.
SnailSpace
That’s the phrase I searched initially but they are all M6. After finding a chart M6 are 0.6mm wide mine measure at 0.5mm wide after measuring, so makes mine M5. They also sell them on Thomann and one of the reviews mentions they fit his older Thomann rack which one of mine is! Sorted!
Edited by SnailSpace - 28 January 2023 at 6:32pm |
SnailSpace
I’ve bought a Power Distribution Unit which has 3 way power surge protection, it also has an ‘earth ground’ point. I have my turntable earthed to my Mixer. I notice that my older QSC 900 USA & dB-Mark DSP have ‘earth ground’ symbol but don’t see anything on QSC GX3 or Crown XLI 3500. Where should I be grounding the PDU too (If at all?) Also I’ve read a lot of debate online about what amp fuse (uk) to have in an iec (kettle) lead from amplifiers/gear etc going into a 13amp uk plug? General opinion in UK? Seems to be 10A online? Edited by SnailSpace - 02 February 2023 at 10:12pm |
