dB-Mark XCA 28 - DSP Basics for a Newbie |
Post Reply | Page 123> |
SnailSpace
Posted: 12 March 2023 at 4:14pm |
I bought a dB-Mark XCA 28 (DSP) a few months ago and recently bought a cheap PC Laptop so I could download the software and use the interface to make learning a bit easier. I’m currently still working on my High & Low boxes but want to learn how to use the DSP on what I will be is using as my Mids for now. Anyway after watching a few basic videos on YouTube from Thai/Vietnam/Malaysian users (this seems to be dB-Marks main market) I now have it working and playing music but the Translate function on YouTube is very sketchy and videos don’t go into the details I need. So this is where I need to pick your brains to learn the basics. The Speakers I’m using (for now! So please don’t ask me why or remind me they are garbage ;) are Jamo 266 D, I have very limited information on them so how do I work out what Frequencies they are capable of producing evenly ‘From’ ‘To’? 4x Jamo 266 D: Short Term - 265w Long Term - 150w 4-8 ohm I will keep it to this one question for now as I have others and don’t want to confuse the issue! Thanks in advance |
Conanski
Well... those are home/studio speakers aren't they? When you play fullrange music through them do they produce what sounds like fullrange sound... within reason?
I don't know what the published specs are but say they cover 60-18khz, you can safely limit that to smaller range without issue.. in your PA system that might be 100-2khz for example. This assumes that the Jamos are fully functional with no blown drivers or other damage of course, is that the case? It's not likely the 12" driver alone would produce much output at higher mid frequencies so the mid driver in this box would come into play.
SnailSpace
Yes Home/Studio ‘all in one’ they are a full range speaker comprising of a Tweeter/5”/12”. I can’t find the Specs unfortunately. Yes fully functional no blown speakers. Thanks I’ll give that range a go…more basic questions to follow ;)
Edited by SnailSpace - 12 March 2023 at 7:09pm |
SnailSpace
Question 2.)
I’ve looked at wiki page and read about the origins but is their a simple short answer - Do these filters apply better to a certain setting of sound system or genre/format of music or are they equally great and it’s personal preference? A. Linkwitz Riley. B. Bessel C. Butterworth Thanks Conanski I’ve used those numbers it sounds nice. Early days of the learning I suppose it gets tricky as I add other outs!
Edited by SnailSpace - 12 March 2023 at 10:37pm |
Conanski
There are some technical reasons you may select one or the other that has to do with the shape of the filter response and it's phase response, in general you won't hear any difference between them. In short LR filters are commonly used in crossovers as even order filters of this type sum to a flat response, and for PA applications in particular... because driver protection is very important 4th order(24dB/oct) or steeper are more common and recommended.
SnailSpace
Thanks Conanski I imagine my learning and understanding of how the DSP & Interface truly works with the Sound System & Mixer will come when I introduce my High/Low outs. Until then I’m trying not to over fiddle too much. I presume limiters and levels on dsp/amps/mixers should be question 4! Question 3.) Noise Gate - I have had a quick look around and whilst I understand it is for cleaning up noise I can’t find any info on setting it on a DSP interface in application to a Sound System? The function seems greyed out at the moment for some reason but was it was on yesterday and I noticed it had a ‘dBu’ up and down setting! Do I fiddle by ear to hear if it is reducing or cleaning any noise or is their a general setting/range that noise occurs? |
Conanski
A noise gate mutes the outputs when the signal levels drop below a preset threshold, the purpose of this is to reduce the amount of idle hiss or other noise from the speakers when nothing is playing. But most audio systems are pretty quiet these days and the one component that can generate quite a bit of hiss.. the amplifiers, are after the DSP so this function may be of little use.
Edited by Conanski - 13 March 2023 at 1:32pm |
4D
60hz might be to low for the Jamo its only a tiny voice coil and they were designed well before modern bass heavy EDM suggest but24 hi pass 70hz or even 80hz (let the port do the sub) lr24 lo pass 20khz
SnailSpace
Thanks 4D will have a look at the difference! They sounded ok yesterday but then again it’s in a home setting so I’m not pushing them.
Surely Bass and speakers that could handle Bass existed pre modern EDM? I’m not doubting that they probably don’t have the best voice coil but they were marketed as DJ speakers during the height of the emergence of Electronic Music and post Reggae and they handle pretty well within reason. Or are you saying the modern equivalent of these speakers would be able to handle more? But I don’t want to over extend them and damage so will take a look as I don’t have the info it is a bit of guess work. That leads to another question how do you know besides blowing the cones if I've got the Frequencies right or wrong?
Edited by SnailSpace - 13 March 2023 at 3:13pm |
4D
That the Jamo's have survived thus far is a testament to their durability. Look at any contemporary speaker with similar components and they mostly hi-pass around 60 to 65hz, so for an old girl 70hz is not unreasonable, if they sound to thwock thwock lower it a bit until satisfied but bear in mind, the lower they play the less power they can handle |
SnailSpace
Thanks.
I take it ‘But’ means Butterworth & LR mean ‘Linkwitz Riley’? Ah so you can use different filters for hi & Lo!
Edited by SnailSpace - 13 March 2023 at 4:14pm |
teeth
yes, and i think BE is bessel on that unit see if anyone has made general videos on LMS / DSP units the ultradrive is often considered a good "beginner" unit, so this video might be helpful now you know your way around the dBmark, you can apply what you have learned from other videos to your unit. it's platform agnostic knowledge :]
Edited by teeth - 13 March 2023 at 4:37pm |
