32A distro splitting suggestion |
_Natty_
Young Croc Joined: 01 April 2007 Status: Offline Points: 664 |
Posted: 24 March 2023 at 1:33pm |
hi to all,
what is best way to split a 32A over this configuration:
To me 1-2 needs both a bull 32A monophase each. Or i can save something? all 18" needs k10 to maximum aviable power aviable to push proper But then ive enouth to power all the rest? thanks
jacethebase
What sort of gigs are you doing?
Screams out 32/3 distro to me that setup.
www.stage2sound.com |
_Natty_
thats a tricky question... depends on venue and how much sound i put out. The configuration described is for large gig around 6-800 people with a stack of 6 scoops. yes splitting x3 is basic but how to distrubuite them the key over tha aviable supply |
levyte357-
What drivers do you have in the Scoops? (E.g 4x 1850s can easily be powered by decent amp of 13A plug) Are you in the UK? (Many venues allowing Reggae sounds, only have 13A sockets) Do the venues you often play in, typically just have 13A plugs, or proper 16A/32A/3PH mains available to you !? E.g., if in the UK, and typically only have 13A plugs available in halls, might be easier having 2x sub amps, running 4 ohm stereo each max, and get 2x Kelsey Type PD7/32, sub amp on each, each distro connected to 13A plug, (on same circuit !!!) Edited by levyte357- - 27 March 2023 at 11:11am |
Spesh
Old Croc Joined: 15 July 2007 Location: Surrey Status: Offline Points: 1606 |
I agree with Lev. I used to run 8x Labhorns & 4x USBs and would run into power issues all the time with venues that only supplied 13A (especially with the Crest CA18s). We used to like the big amps because they sounded weightier on sub duty than bridging smaller amps, but with modern amplification this is no longer the case. Unless you are confident you'll have access to 16/32 or 3 phase, I'd personally split the amps up. Edited by Spesh - 27 March 2023 at 6:03pm |
Symmetry Soundsystem
levyte357-
Crest CA18, is completely different level of bass amp, when on proper power !! Back on topic. Powersoft K20, really does well, when asked to perform off 32A consumer ring main/13A plug, but have seen for myself, this is subject to the ring main sagging, due to wiring, other consumer devices on the ring main. Yet again, is completely different amp, when on dedicated 32A spur, with no mains sag. There seem to be increasing options, for modern cheaper lightweights, optimal for 4 ohm stereo, and for UK, working off distros, connected to 13A mains plug. Edited by levyte357- - 28 March 2023 at 11:21am |
4D
If I wanted to run off three different sockets (one each for the k10's and everything else of the third feed) I would probably pack the following distro to give me max copper. 3x 3g1.5mm horn7-f 13A/16A converter3x 3g1.5mm horn7-f 16A/13A converter. 2 x 13A 3g1.5mm Horn-7 to 13a 4 gang extension 3 x 5M 16A extension cables 3g2.5mm horn7-f ( 3 x 10M 16a extension cables 3g2.5mm horn7-f That way all the long cable runs are on 2.5mm lengths can selected depending on circumstance. I like to ask to see the venues power distribution unit (fuse box) check the fuse ratings and test the rcd's on the relevant circuits & If poss pull power from different 32a ring circuits within the venue. Edited by 4D - 28 March 2023 at 10:18pm |
levyte357-
Mykey Wattco said decades ago, if in UK, and in hall/room, with just 13A plugs, always good idea, to check if power can be drawn from kitchen (unused during gig), if there is 32a plug top. But all this "sort of thing", really does need "accomplished sparky". Professional sparky told me years ago, if you don't know what you are doing, and screw around with electricity, it will kill you. Edited by levyte357- - 29 March 2023 at 10:12am |
Spesh
Remember the old horror stories with two 13A plugs wired in parallel, fuses replaced with nails. If one plug was removed from the socket while the other was still receiving power, live pins would be totally exposed? I've even seen a few home brew distros on here with 32A female input sockets. The mind boggles!
4D
I am suggesting checking if there are multiple ring circuits within the venue and if so using a 13a outlet from each ring I am not suggesting hacking into a live fuse box. Checking how to isolate the supply measuring the voltage, checking polarity & fuse rating along with testing rcd's/rcbo's is not rocket science and should not be dangerous. Affordable tools are available a cheap socket tester from amazon will tell you most of what you need to know along with a simple rcd tester fluke st240 springs to mind. If you are likely to be held liable as senior responsible person for electrical safety then requirements for a completion certificate for small systems under bs7909 it is worth reading up on.. Heres an overview with more if you dig https://www.bbc.co.uk/safety/resources/aztopics/temporary-electrical-systems/ Or James Eade has similar data |
levyte357-
Hi, not suggesting you said anything about messing with fuse box..
Just reminding OP, respect electricity, it kills those who don't.. |
_Natty_
thanks to all contributors,
and apologize my long delay, im from italy so from civil supply we found things like https://en.wikipedia.org/wiki/Schuko thats are 16A plug, but my configuration is for venue thats offer CEE power supply, 32A. main question if 2 phase going to each k10, it will be enough all the rest on the last one splitted in 2? For all the rest i mean:
For "civil" supply i will use the 16A shucko reductor and lots of pray. -ive runned lots of times struggle on it, but k10 solve a lot of my problem, less power yes, but few risk on a 16A civil too- Edited by _Natty_ - 18 April 2023 at 3:45pm |
