extremely high efficiency |
Post Reply | Page <1 234 |
Author | |||||||
MarjanM
Toasty, two things.
First, you aint old :) Second, 50x60m is 3000m2. Using the formula of 4.7 people per sqm that is way more than 3-4000 people ;) Third :) We miss you! |
Besa
Registered User Joined: 04 June 2018 Location: Italy Status: Offline Points: 49 |
So Danley can cover 12-14k ppl crowd with a couple of j7/j8?
That’s astonishing. Seriously. |
Xoc1
Hi Kyle. Good to know your still around, and prepared to rise above the stench.
Phil B
Kyle !
I'll concur with the fellow SPers and I thought your quote was going to be Captain Willard from Apocolypse Now ... " Oh man...the bullshit piled up so fast in Vietnam, you needed wings to stay above it." And you ain't old yet fella... .p. |
Earplug
With age, comes wisdom. That's my excuse, anyway. |
Bams
So...we can all stop with this nonsense since we lured Kyle back from retirement ? ;)
fudge22
Registered User Joined: 26 July 2022 Location: UK Status: Offline Points: 65 |
It might be worth checking your shoes.
To copy and paste from M-Noise’s procedure page:
It also states:
Here is a link to the page I quoted. https://m-noise.org/procedure/ - https://m-noise.org/procedure/ I may have missed it, but I don’t see any documentation
regarding the measurement procedure on the Danley website. Yes M-Noise is a
recognised standard, but anyone can download the audio file and truthfully
claim to have measured their device using the M-Noise signal. Without the
documentation it doesn’t conform to the standard, which as you say is about
repeatability. Without the set-up documentation how can you repeat the measurement?
If anyone has a copy or link to Danley’s documentation I would be interested to
see it. If the figures are accurate, it is good news for the home
constructor, because it shows that a simple calculation can get you quite
close.
If you notice the last part of my statement that you quoted
I said “unless by efficient you mean highest output from smallest box.”
Generally, in engineering, this is not what is meant by efficient.
Could this be what is affecting your olfactory system. The
images might look pretty, the information is probably correct, but it is the
answer to a different question. In the context of this thread, comparing the
Danley system to a large line array it is irrelevant. The original poster was
asking about designing and building an efficient system, not whether a Danley
system is comparable to a12 a side d&b KSL.
I think that it is a reasonable assumption that anyone
asking how to design a speaker cabinet, on this forum, is unlikely to be
deploying their resulting work at a height sufficient to ensure free-field
conditions. If this is the case then you agree that your calculations are
irrelevant. As the original poster has not returned since his three initial
posts, perhaps he has found a solution to his question or got bored and moved
on to some new project. If he is reading this perhaps he can let us know. |
godathunder
Old Croc Joined: 19 July 2004 Location: wicklow Status: Offline Points: 1833 |
ĭ-fĭsh′ənt adjective
in common usage I think efficiency is a useful term to describe the effectiveness of a tool or method. in engineering terms efficiency is a percentage and requires
comparison of measurements using the same terms - eg: watts out/watts in
= %efficiency So would it be more satisfactory to your inner enginner if we described the danley box as an efficacious tool? |
LOUDER THAN LOUD
