Mth 46vs question |
Joey carlo
Registered User Joined: 18 October 2018 Location: Peterborough Status: Offline Points: 36 |
Posted: 23 May 2023 at 10:11am |
Hey , not posted her for a while but got the bug again and actually making full use of my sound system๐
So i had 18" scoops but wanted to try something different, i like scoop but they always seem to be missing something when playing house music (the normal dip they have) really shows on house music and i wanted something smaller and flatter in the 50-120hz range. So i see these and thought , easy build, measurements look good and i already have the 18g401 to load in them so i built them (took only a couple of hrs each to knock together) Really like the sound they produce , compete with scoops in regards to "weight" and also have that higher thump i was after. Really happy. So my question is , i need to place handle and optimum position is in throat are infront of driver , now will that affect the tuning of cabs? Maybe someone can help me with that? Would be ๐ Thanks
Edited by Joey carlo - 23 May 2023 at 10:12am |
bob4
If you place it in the middle of the cone it will be fine. If you make a butterfly routing & backing box, it might even act as a crude cone correction (google it)
Edited by bob4 - 24 May 2023 at 8:12pm |
Joey carlo
Interesting , ill look into that! thanks ๐
Anyone else built these cabs? would be good to get opinions! I like them alot. It isnt a true th from what i can see, almost th / paraflex hybrid maybe? But works great , spl lvl are real good and pretty flat ๐
