  New Posts New Posts RSS Feed - Paraflex techno rig ?? advice needed.
Bassjamin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bassjamin Quote  Post ReplyReply Direct Link To This Post Topic: Paraflex techno rig ?? advice needed.
    Posted: 03 December 2023 at 12:35am
I am currently looking to purchase/commission my first rig.
I have been running jungle/dnb/techno gigs for up to 1000 ppl indoor and outdoor. Most experience is with void systems
I have a budget of 45 - 50 K.
I have been getting alot of mixed advice and don't know what to believe from probably the wrong people to be listening too 😂😂
I was pointed down the line of 4 danley sh46s, (if there would be something more suited for the same price range I'd love your suggestions) on-top of either hog scoops like eletrikals and es 18s.
Or I have been told to look down the paraflex route and I have been looking at 8 21" and 8 18" kicks basically like sanai but with the danley horns on-top. Any suggestions or advice would really be appreciated.
I'm not sure If the hogs or paraflex system is fast enough for a 140 bpm techno set, so I believe I might need to make a trade off for either dnb/jungle deep bass or fast tight punchy techno. I'm guessing the universal answer to it all would be a void system ? This would also be possible but if a scoop or paraflex rig could work I would prefer to go down that route.
Thank you so much for reading I appreciate any advice, experience or help that could be shared. I love the community spirit on here.
I'm not looking to copy anyones rigs or brands I have artists in line to completely customise the setup, it will be completely unique.
FOO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FOO Quote  Post ReplyReply Direct Link To This Post Posted: 03 December 2023 at 8:41am
First of, what currency do you operate with? That would be a good start to know.
Sinai Sound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sinai Sound Quote  Post ReplyReply Direct Link To This Post Posted: 03 December 2023 at 8:57am
Where are you based?
If it's near Sheffield, and you're free in an evening mid week, bring some music and coming and listen to mine
Like them or not, at least you'll know
Post Options Post Options   Thanks (0) Thanks(0)   Quote Earplug Quote  Post ReplyReply Direct Link To This Post Posted: 03 December 2023 at 9:51am
Yes, definitely depend where you are based.
In the UK you will have a different base of choices to say, the USA - or on the continent. Down where I am, TWA is definitely the flavour of the month. You could definitely get enough TWA gear for what you want on that budget.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bassjamin Quote  Post ReplyReply Direct Link To This Post Posted: 03 December 2023 at 10:45am
Wow that would be amazing I will definitely take you up on your offer.I live in Ireland but I can jump on a plane rent a car no problem, I can come over for the week so whichever evening is ideal for you. Really appreciate the opportunity Can I pm you ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bassjamin Quote  Post ReplyReply Direct Link To This Post Posted: 03 December 2023 at 11:03am
Sorry I'm based in Ireland, but I'm planning on purchasing through the UK
I can easily change currency about 40 + and a couple pounds. Thanks for the help guys.
I've been going to gigs to listen to different sound systems, jungle and dnb does not seem to be an issue whatsoever. It's the techno capabilities that I'm unsure about as I've only heard jungle/dnb/dub at the Giggs, when it goes to techno I'm finding a void stage.
I suppose I'm looking for any experience on rigs paraflex/transmission line that play techno. I'm hoping that for what I can spend on void I can get a hand built rig with similar capabilities.
Being able to come and demo my own tunes would answer most of my questions and would be a huge help so thank you so much for the offer again.
hmaudio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hmaudio Quote  Post ReplyReply Direct Link To This Post Posted: 08 December 2023 at 6:43pm
Bassjamin if you need a cabinet builder i have plenty of experiance with paraflex and can help get you in the right direction. look for HMAUDIO on facebook or instagram and if you need any help get in touch
FlipC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FlipC Quote  Post ReplyReply Direct Link To This Post Posted: 28 February 2024 at 5:30pm
So you must think about storage, transportation, and setup.
Techno is 909 and Jungle is and 808/106.
So you need something that can do both fast attack and slow roll off at least down to 30hz.
DSL is audiofile in the least amount of boxes.
Void is the coolest looking.
F1 is F1.
All 3  can be configured in multiple ways and sound great.
All 3 cost $$$$.
For DSL type speakers go to DIYAudio.
The unity style horns. Nothing compares. Rough guess in build cost is $1K USD per. Really only need a pair for 1k people. Dependent on build.
I personally use 12 15" tapped horns.
Technically  a 40hz box. Just shy of 105db per. Depending on setup this does 140 plus DB and usable output down to high 20s. Sharp cut off due to cone excursion control. No DSP. Run them up to either 110 - 125 hz room dependent. And the BIG thing to me, I can lift a box easily.
 TH's sound wise are a FLH and a Reflex mixed.
If you think of this route, again look over at DIYAudio.
Last, and flame on.
Save $. on amps Admark, CVR, Sinbosen.  Spend the $ on the speakers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 01 March 2024 at 10:49am
Your budget will buy you something like this in a turn key way with all the electronics included.
