  New Posts New Posts RSS Feed - System build for new venue
Midwife View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Midwife Quote  Post ReplyReply Direct Link To This Post Topic: System build for new venue
    Posted: 27 March 2025 at 10:42pm
Hello all!
I'm currently pitching a custom build for a client opening a small venue that caters for both electronic and acoustic events and quite versatile in their programming.
I'm currently r&d'ing what boxes would be best to approach them with, however it's quite a challenging space - It's not the largest footprint and the room is slightly tapered with 5 meter high ceilings, and the capacity is around 120 ppl.
For this reason I thought that reflex boxes may be a bit washy in a cavernous space but also horns could be a little problematic creating a load of reflections / deadspots. A mate of mine did say to look into some paraflex boxes though. But yeah the idea is to have a couple of subs, and maybe a kick/top or separate.
I'm fairly new to this side of audio so any help / suggestions to what designs might be suitable would be great. I'm a joiner so putting the boxes together won't be an issue at all 🙂
I've attached a pic of the space and a vague floor plan with the event space circled if that's any use.
Cheers!
https://imgur.com/a/JqNLa9D
Conanski View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Conanski Quote  Post ReplyReply Direct Link To This Post Posted: 28 March 2025 at 1:02am
Reflex (direct radiating) designs are the swiss army knife of speaker systems, appropriately sized and processed they will support one genre as well as the next.
Horns have thier advantages and can also be a universal tool but are harder to integrate with the room and with each other.
That ties in nicely with the next point, what does the room look like.. hard surfaces everywhere or are there some absorptive materials in place?
What speaker locations are available? Is there space to put larger horn loaded speakers without taking away seats/capacity or obstructing views.
Horns look cool and can bring a certain vibe but the primary goal is good sound and more compact designs can deliver that too.
Jan-2T View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jan-2T Quote  Post ReplyReply Direct Link To This Post Posted: 28 March 2025 at 9:04am
Haha, this room is horn shaped LOL
Music!
Line Array View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Line Array Quote  Post ReplyReply Direct Link To This Post Posted: 28 March 2025 at 10:34am
does the whole space need to be covered or is there a dance floor area somewhere in the middle ?
how drunk are the people going to be ?
do they need to be able to hear each other over the dining table ?
Edited by Line Array - 28 March 2025 at 11:22am
snowflake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowflake Quote  Post ReplyReply Direct Link To This Post Posted: 28 March 2025 at 12:10pm
please don't build any more paraflex speakers LOL
from the venue point of view - if it's a new venture they should just hire or buy some second hand equipment and experiment with that for a while until they decide where they want the speakers and how loud it needs to be. And work out if the business is actually sustainable before they spend money on a custom built system.
madboffin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote madboffin Quote  Post ReplyReply Direct Link To This Post Posted: 28 March 2025 at 2:32pm
It's a small room, looks like about 15m x 4 / 6m, bit with the 5m high ceiling. Side walls and floor/ceiling are not parallel, which may be helpful.
It looks like a good candidate for a system designed for high quality and plenty of headroom, if done properly
Various things need to be considered first, as they affect the choice of speakers and where to put them.
Your first requirement will be some acoustic treatment, starting with hanging some (suitably fireproof) drapes in the roof area. Plus some treatment on the rear wall and probably the sides too.
Speakers need to be a couple of metres above head height and angled downwards to cover the audience rather than the walls.
Will the room always be be used end stage, or are the mics likely to be used anywhere (corporate events etc)?
Also from the drawing there appears to be only one entrance / exit - I'm sure you will need to add another before you can use it as a venue.
As above, horn loaded bass / subs may not be a good choice in this space.
Edited by madboffin - 28 March 2025 at 2:33pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote RoadRunnersDust Quote  Post ReplyReply Direct Link To This Post Posted: 16 April 2025 at 5:06am
THIS!
Quote from the venue point of view - if it's a new venture they should just hire or buy some second hand equipment and experiment with that for a while until they decide where they want the speakers and how loud it needs to be. And work out if the business is actually sustainable before they spend money on a custom built system.
And this! LOL
