What ply for bins? |
Page 12> |
smash-monkY
Joined: 11 August 2024 Location: UK Status: Offline Points: 21 |
Topic: What ply for bins?Posted: 03 July 2025 at 12:57pm |
Hi all.
What's the best ply to use to build a 21" bin? I'm a little flummoxed by the price differences... On one hand you have this at £40 a sheet inc. VAT... and on the other hand you have this from £90odd +VAT... Advise please?
snowflake
Joined: 29 December 2004 Location: Bristol Status: Online Points: 3443 |
Posted: 03 July 2025 at 1:05pm |
the cheap one is pine which has a much softer surface to it. cabs made of that will end up covered in dents and cracked paint. always use B/BB birch for external parts. I use a good quality poplar for internals as it saves about 8kg per box - it's not much cheaper than the birch though.
VECTORDJ
Joined: 11 June 2006 Location: United States Status: Offline Points: 585 |
Posted: 03 July 2025 at 6:41pm |
Baltic Birch is the Best by Far...Worth the Extra Cost....VECTORSONICS.
smash-monkY
Posted: 05 July 2025 at 8:53am |
Thanks for the advice. |
snowflake
Posted: 05 July 2025 at 10:46am |
yep
woody2
Posted: 05 July 2025 at 7:07pm |
Just make sure you don't get chinese B/BB, it will delam...
1ManSoundsystem
Posted: 25 July 2025 at 10:41pm |
heres small hint from me: i got a buddy who works in construction in- and outside and also sometimes does clearing out apartments. 2 months ago i was told, they had a 5room aptm. with lots of stuff to loot. i went there, and discovered what was about 2500Eur in birch plywood sheets. all 18-21 some 24mm, all 60x180/200 some smaller some wider. about....600? kg. for free. some sick brains decided to build wardrobes cupboards beds - everything out of this stuff. excellent building stuff. so if u know someone, ask them, maybe youre lucky. recent prices for birch plywood are grotesque so even chances r low, who knows. and yeah, good quality birch plywood is best for building cabinets. do urself a favor and avoid mdf and raw chipboard. only reknowned big brands build with this crap like HK audio :) (trashbrand)
HumbleDeer
Joined: 04 May 2017 Location: Belgium Status: Offline Points: 35 |
Posted: 26 July 2025 at 3:21am |
Eh, Pine and poplar plywood panels aren't only softer but they will have different resonance characteristics and that's especially important if your box relies on stiffness of itself to have a predictable cutoff/rolloff, or if your box is meant to resonate partially or as a whole.
SamV
Joined: 21 October 2008 Location: London Status: Offline Points: 8783 |
Posted: 28 July 2025 at 1:27am |
Glad to see prices coming back down
smoore
Joined: 30 March 2011 Location: N.Devon Status: Offline Points: 966 |
Posted: 28 July 2025 at 10:10am |
The hardwood plywood from wickes is pretty damn good for the price I think. About 1/3rd the cost of a sheet of Birch at the moment. For sure it won't last as long but you'll get many years out of a cabinet if you don't throw it down the stairs too often.
smoore
Posted: 28 July 2025 at 10:12am |
*Note i'm talking about the Hardwood plywood (non-structural) - https://www.wickes.co.uk/Non-Structural-Hardwood-Plywood-Sheet---18-x-1220-x-2440mm/p/110037
The structural stuff is softwood faced and from memory is broken more easily.
dj-mip
Joined: 14 July 2011 Location: Bournemouth Status: Offline Points: 15 |
Posted: 13 November 2025 at 12:37am |
you can normally tell if its good ply just by the laminates. If its got 13 laminates for 18mm ply its likely gonna be good but if it has 5 / 7 or 9 layers its basically shuttering ply and no good for speakers. If the speakers are not going to be moved about u can use mdf u just got to seal the edges properly. No good for touring stuff tho . 13 is the magic number for 18mm ply ..
a.t.m.
Page 12> |
