  New Posts New Posts RSS Feed - speaker foam
speaker foam
invader View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote invader Quote  Post ReplyReply Direct Link To This Post Topic: speaker foam
    Posted: 25 January 2026 at 1:39pm
looking for suggestions on best glue to use for glueing foam to meal speaker grilles
Andylaser View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andylaser Quote  Post ReplyReply Direct Link To This Post Posted: 25 January 2026 at 2:15pm
3m super 77
"music so loud, that if we move in next door to you; your lawn will die" - Lemmy
cravings View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 25 January 2026 at 6:46pm
It's true. It's pricey, but other ones just make a mess.
KDW32 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KDW32 Quote  Post ReplyReply Direct Link To This Post Posted: 25 January 2026 at 7:42pm
Evo stick spray contact adhesive worked for me in the past.
madboffin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote madboffin Quote  Post ReplyReply Direct Link To This Post Posted: 26 January 2026 at 3:48pm
That's very hard to control and can make a terrible mess. You might get away with it after a lot of practice on scrap parts, but I wouldn't...
The Scotch 77 is much better for this application and is used in the industry (including at Martin Audio when I was there). But yes it is very expensive.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Earplug Quote  Post ReplyReply Direct Link To This Post Posted: 26 January 2026 at 4:41pm
I've never used the Scotch 77 stuff, but have used several generic contact sprays, including the Evo & never had any problem. What exactly do you mean by "terrible mess"?
I think that you just need to be careful & use careful, short bursts & not spray the stuff all over the place like a maniac!!   LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 26 January 2026 at 5:10pm
if you're doing foam on the inside of the grill, other glues make a spidery mess.
but if you're gluing foam to the outside of the grill, then others are probably fine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Earplug Quote  Post ReplyReply Direct Link To This Post Posted: 26 January 2026 at 6:16pm
Ok.
I usually stick the foam on the inside, but have had to repair a few with the foam external. Never really noticed the problem. Maybe I've been lucky.
smithers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smithers Quote  Post ReplyReply Direct Link To This Post Posted: 04 February 2026 at 10:31pm
As per forum recommendations, I used the 3m super 77 to refoam a basys rig (foam inside the grill), its about £13 off amazon.
Honestly, dont waste your time using anything else, super 77 works exactly how you hope it would. the results are very impressive.
