  New Posts New Posts RSS Feed - ls2000 nexo
ls2000 nexo
 Post Reply Post Reply Page  <1 34567 18>
Post Options Post Options   Thanks (0) Thanks(0)   Quote Heathrow_B_line Quote  Post ReplyReply Direct Link To This Post Posted: 04 March 2008 at 9:04pm
you need to try those horns. buy me some mdf and i will knock you some up for a laugh
ps i will try building the ls2000 with some pd1850 drivers... what do you think?  when i get the plan i will try and model it up in winsid
tb_mike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tb_mike Quote  Post ReplyReply Direct Link To This Post Posted: 04 March 2008 at 9:31pm
ls2000 is a bp6 with 2x18" ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Heathrow_B_line Quote  Post ReplyReply Direct Link To This Post Posted: 04 March 2008 at 9:35pm
yes
Post Options Post Options   Thanks (0) Thanks(0)   Quote tb_mike Quote  Post ReplyReply Direct Link To This Post Posted: 05 March 2008 at 12:35am
Originally posted by Heathrow_B_line Heathrow_B_line wrote:
yes
Howcome it sounds so good thenBig%20smile
Whats the magic? is it because the si2000 reaches to ~50hz well ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Heathrow_B_line Quote  Post ReplyReply Direct Link To This Post Posted: 05 March 2008 at 12:37am
when i get my hands on some i will let you know
lol
csg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote csg Quote  Post ReplyReply Direct Link To This Post Posted: 05 March 2008 at 9:49pm
its a deal HBL, im interested to see if we can do a kind of infrahorn for these. im back from hols soon, so we can finally have a look at these subs
Mike - when using with the si2000, the ls2000 only run 28 - 55hz, and when used with the smaller msi system, they run from 28 - 75Hz. i think that both sides of the bandpass have been tuned quite close together to help overall sensitivity and output.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tb_mike Quote  Post ReplyReply Direct Link To This Post Posted: 05 March 2008 at 10:26pm
Ah - A narrow bandwidth would help the BP6.I remember being silly with winisd years ago and making super peaky 40hz-50hz F3 Bp6 designs,wondering if they would have +15dB gain heh.
A few si2000s for SO many people! Page 157+ of show your sound system thread.
Whats the trickyness with the midbass folded horns??
csg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote csg Quote  Post ReplyReply Direct Link To This Post Posted: 06 March 2008 at 7:19am
perhaps the power handling - using the td controller i safely put 1600w rms into each 15" driver ( modified rcf l15 p200ak 4 ohm), so am using 3.2k per bin. they are efficient as well - most people assume they are 4th order bandpass horns but they are longer horns with compression plates infront of the drivers, and a reflexed rear chamber which adds significant output to the lower area of frequency output. they are a very musical and articulate bin which when used in pairs go supprisingly low and are very punchy - excellent transient attack.
the only problem i have with this rig is it phisically looks too small for a lot of people - i frequently get comments asking where the rest of the rig is.......untill i turn it on!
stevo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stevo Quote  Post ReplyReply Direct Link To This Post Posted: 16 March 2008 at 4:40pm
hi  hows it getting on ?
csg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote csg Quote  Post ReplyReply Direct Link To This Post Posted: 20 March 2008 at 11:14pm
sorry to keep you all waiting for plans - im just too busy with work at the mo. i keep thinking that the next week will be quieter, but its not panning out.
I have decided that i want to build another 4 ls2000's so plans will definately have to be made.
VlatkoT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote VlatkoT Quote  Post ReplyReply Direct Link To This Post Posted: 20 March 2008 at 11:36pm
waiting for it
Why to live 7 days like a poor idiot When you can live 100 years like billioner
Post Options Post Options   Thanks (0) Thanks(0)   Quote Heathrow_B_line Quote  Post ReplyReply Direct Link To This Post Posted: 27 March 2008 at 6:24pm
no promises but i may be able to get afew of these made on a cnc depending on the timing
