  New Posts New Posts RSS Feed - ls2000 nexo
ls2000 nexo
 Post Reply Post Reply Page  <1 1314151617 18>
t0m View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote t0m Quote  Post ReplyReply Direct Link To This Post Posted: 22 April 2009 at 12:49am
Very interested to know how you get on Stevo, I have 2 of the LS2000's with the Nexo controllers and I absolutely LOVE the sound of them, nothing else drops as low and sounds as nice in my opinion!
What have you loaded them with? Are they 13lam 18mm birch ply? Do you have a controller to run them from? What amps are you going to be using?
Cheers!
//t0m
http://www.microrave.biz
PA/Sound/Staging/Lighting & Laser Hire for London & the whole of the UK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Heathrow_B_line Quote  Post ReplyReply Direct Link To This Post Posted: 22 April 2009 at 12:53am
tom
whereabouts in london are you?
t0m View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote t0m Quote  Post ReplyReply Direct Link To This Post Posted: 22 April 2009 at 9:56am
I'm South East just off the Old Kent road.
//t0m
stevo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stevo Quote  Post ReplyReply Direct Link To This Post Posted: 23 April 2009 at 10:19pm
i have used far eastern 18mm ply loaded ftr18's i be running them on 2 studiomaster 1000 but will be changing them to something with bit more power, i loved building these i love the sound of these cabs , will see if they sound good with the ftr instead of rcf
Post Options Post Options   Thanks (0) Thanks(0)   Quote stevo Quote  Post ReplyReply Direct Link To This Post Posted: 24 April 2009 at 10:05pm
right a important question wiring to drivers , surely wiring to 1 is reversed so they both push and pull the same air 1 push 1pull  , as they would cancel each other out when they both push  ? as one driver faces in the cab and 1 faces out
test time tommorow night
Edited by stevo - 24 April 2009 at 10:09pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote stevo Quote  Post ReplyReply Direct Link To This Post Posted: 25 April 2009 at 3:43pm
powered up as couldnt wait, they got some poke! sound good, wish i have more power to see what they really can do
Post Options Post Options   Thanks (0) Thanks(0)   Quote stevo Quote  Post ReplyReply Direct Link To This Post Posted: 26 April 2009 at 9:41pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote stevo Quote  Post ReplyReply Direct Link To This Post Posted: 26 April 2009 at 9:43pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote stevo Quote  Post ReplyReply Direct Link To This Post Posted: 26 April 2009 at 9:44pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote stevo Quote  Post ReplyReply Direct Link To This Post Posted: 26 April 2009 at 9:45pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote stevo Quote  Post ReplyReply Direct Link To This Post Posted: 26 April 2009 at 9:46pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote stevo Quote  Post ReplyReply Direct Link To This Post Posted: 26 April 2009 at 9:58pm
