Guide to WinISD Pro and Hornresp |
Post Reply | Page <1 678910 12> |
Centauri
Old Croc Joined: 29 November 2004 Location: Newcastle Aus Status: Offline Points: 1792 |
If you had a look at the link I posted further up this page, it directs you to the current site at http://www.hornresp.net.ms/
brooa
Registered User Joined: 23 August 2011 Location: Australia Status: Offline Points: 162 |
which isnt working lol which was the point
Centauri
Working fine for me .....
brooa
really? ffs i will have to try it through a proxy or something. asked a few diff people down here to check and they couldnt access it? how bizarre edit: works fine on my phone so must be an isp issue? either way the actual link for the file was http://www.hardware-test.org/
Edited by brooa - 07 February 2012 at 2:36pm |
Priit Pavelson
Registered User Joined: 28 December 2011 Location: Estonia Status: Offline Points: 17 |
Very helpful...thanks :) download works.
tv00
Yes, I have one question about horresp modelling regarding driver sensitivity:
How do i get that into account? the rcf mb15n401 has 100db sensitivity & the lf15n401 has 97, but they model the SAME in hornresp. Appart from different sensitivity the also have different BL & so on. HElp appreciated (I'm buying 8pcs for my tms-2 like NOW:-) |
dizzydotdot
Registered User Joined: 27 August 2012 Status: Offline Points: 14 |
shon35us
New Member Joined: 24 June 2009 Location: Farmington Status: Offline Points: 9 |
I can't seem to enter L34 or L45 info
Centauri
You need to specify the expansion of that segment first - double click on the L34 or L45 label to select the expansion type - alternatively, whilst the field is selected, press C, E or P keys to change it. |
shon35us
thanks |
winni
New Member Joined: 02 October 2012 Location: Slovenia Status: Offline Points: 9 |
Hello. I have question about winisd. I just insert values of G-SUB with exact port size and 330L internal volume (RED one) and then another with same port size like G-SUB but with 500L volume. I use 18SOUND 18LW2400 subs. I'm completely new in sub design and try to find out which design seems better (for live PA sound, etc.)? Higher SPL for 2dB (330L) or lower SPL but still reachable on 30Hz (winisd predict 95dB SPL)? Sorry for my baad English |
Centauri
Look at your maximum spl and maximum power charts - the larger, lower tuned box may well run out of linear excursion too early to be useful.
