inside a blackline h3 |
Post Reply | Page <123> |
wideload37
Registered User Joined: 05 July 2008 Location: oxford Status: Offline Points: 26 |
lol sry my bad didnt read that bit in the explanation could u instead tell me if the ports are simply flush or are longer? and does the lf horn fire into the space behind the mid horn? just trying to get a picture in my head how its kinda set up.
thx again
james folkes
Old Croc Joined: 08 January 2005 Location: United Kingdom Status: Offline Points: 3064 |
the ports on the h3 are pretty deep yeah, they are as deep as the mid horn is long. you should be able to see this by the way they are flush with the 10" baffle in the second picture.
the 15" lf driver is very close to the mid's back bowl, it fires nearly vertically down, ever so slightly tilted towards the rear of the cab. it is a very good use of cabinet space, although not quite as good as the res2. james.
mardy hippy.
rich_gale
lovely cabs. i like the mid/high section on this cab. may well try replicating the mid section into something im playing with atm. nice thread.
manudj91
New Member Joined: 23 May 2011 Location: Italia Status: Offline Points: 3 |
hi, i've martin audio h3 and i whant to now if all the h3 makes a farty noise when play? thanks
manudj91
< ="utf-8">hi, i have martin audio h3 but the 15 makes a farty noise when played, is normaly for this speaker? thanks
rich_gale
no. probably need a recone, or there might be something in the horn hitting the cone? maybe a plastic beer glass?
manudj91
< ="utf-8">no, I've already checked, it's like touching wood, keeping the volume downbecause it does not, it does give more power. In addition if I raise the cone does not do a bit more.
i don't understand.. |
Plaguesguitarist
Old Croc Joined: 30 April 2009 Location: Lincoln, Earth Status: Offline Points: 2238 |
Good Cabs these. Handles are slightly in the wrong place for my mind.
Not a patch on their predecessors though - The RS800's. Done side by side testing in a lincoln venue.
But then again, i'm prejudiced. i've got rs800's.
To steal MY sharpie. |
Jimmer
Old Croc Joined: 30 April 2010 Location: Stroud / Glos Status: Offline Points: 2605 |
No
discosucks
Old Croc Joined: 06 November 2009 Status: Offline Points: 1548 |
All you need is a boot.
cookie-dj
can someone revive this thread with all pics? always wanted to know how one of these looks inside
You can't polish a turd!
discosucks
I have pictures of the inside of mine Ill see can i dig them up .
