the best speaker for wsx? |
Post Reply | Page 12> |
NUNO
Registered User Joined: 12 April 2007 Location: Austria Status: Offline Points: 4 |
Posted: 08 February 2008 at 11:03am |
i searched a lot, but my english is very bad, and so its very impossible to find the best speaker for "WSX", because i dont understand specific words
i think the best are: the RCF L18P300 ( i know martin takes those, only with 600w) the PD1850 the V-18 1000 the V-18 1200 can there be problems ore something if i will tage other speakers as rcf into the wsx? what is the lowest driver, with the most output? i want the wsx blow me away^^ first i need only 2, but there are comming more... thank you! |
MarjanM
I dont think you will be able to hear what they can do (blow you away) in a just one pair. As any good horn loaded sub it takes 4 to achieve its real potential.
As for the drivers RCF has a new 18P300 that is 1000W RMS. Other options will be: 18 Sound 18W1400 18W1000 RCF 18S800 18N401 And Void V-1000 is a very good one if you can find it in Austria. |
levyte357
The 10,000 Points Club Joined: 10 May 2004 Location: UK, London Status: Offline Points: 11743 |
I would say the only drivers with Enough Xmax, and BL/parameters compatible with WSX in order of preference are,
1. V18-1000 The best driver in this cab. Has more Xmax, BL and better EBP/harder cone than anything else. High BL /smaller Vas/large Xmax mean no other driver will acheive the SPL @40hz that this driver can before max excursion. Will handle approx 1kw 2. L18P300 - Will sound very warm upto approx 700 Watts, where Xmax runs out @ approx 40hz, but quality driver. 3. 18SoundLW1400 - Will handle little more power than RCF, but more expensive? The other RCF's look good on paper but sound crap or can only handle 600-700W if low cut at 40hz, I know someone who has tried them. Edited by levyte357 - 08 February 2008 at 4:02pm |
NUNO
ok, thank you for the answer...
the v18-1000 was my fafourite, but i think now i can be sure... but i must have mutch luck to find them in austria, right! yeah, 2 wont be very hard i know, but its only the beginning, there must comming more.... maybe some other can write, who has tried them and heard the void into the wsx thanks |
twinypaul
Registered User Joined: 25 November 2004 Location: United Kingdom Status: Offline Points: 276 |
we put the celestion ftrs 1000s in ours they sounded wicked
paul
NUNO
the v18-1000 have a xmax with 10,5mm
isnt it too mutch for the wsx? i dont want to kill them! |
tb_mike
Old Croc Joined: 01 October 2004 Location: New Zealand Status: Offline Points: 2744 |
Higher Xmax = Mehr besser! 2 Against a wall should be just ok. Edited by tb_mike - 09 February 2008 at 10:16am |
levyte357
Good to hear that mate. What is the max power the drivers have survived, and what low cut freq do you use? |
mykey
NUNO
hey..
but isn't directly in front of the speaker a plate? my question is; is a xmax of 10.5 mm ( void V 18 1000 ) not too much?wouldn't the membrane hit against tthis plate? ( im talking about the the round plate with the rectangular hole in it) im sorry about this bad english greetz |
MarjanM
Check the plans carefully. It has recessed circle on the baffle where the suspension will be able to his the baffle.
twinypaul
we had 2 a side of a vz 5000 from about 40hz to about 100hz i think we pants them all day they are still alive/ xxls sound better
paul
