  New Posts New Posts RSS Feed - Bill Fitzmaurice - Omnitop 12s (built by Insomnia)
 Post Reply Post Reply Page  <1 4567>
Disco Stu View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Disco Stu Quote  Post ReplyReply Direct Link To This Post Posted: 28 January 2010 at 11:59am
My Omnitop 12s as depicted on the first page of this thread are now up for sale.
Looking for £550 for all 4, simply to help cover the cost of having a pair of OT15s built (priorities change so my PA needs to).
PM if interested, a member of BFM site already has first refusal.
Stu
All you need to know is:
My acts:
trentp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote trentp Quote  Post ReplyReply Direct Link To This Post Posted: 17 January 2013 at 6:14pm
Hi Stu, can these perform well above some ES18'S and Hogs? I need to build some simple but adequate tops.
Dub Specialist View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Quote  Post ReplyReply Direct Link To This Post Posted: 18 January 2013 at 1:22pm
Can someone correct me if im wrong is this the Original Omnitops 12s ?? Yes or No the reason why im asking i seen loads of differenet pics online/forums ect that are single 12s, a row of piezos running vertical twin 12s ect ect but there called Omnitops 12,
what drivers are recommend for this cab too? , or orther alternatives drivers
so are some of these modded cabs?
thanks
all bass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote all bass Quote  Post ReplyReply Direct Link To This Post Posted: 18 January 2013 at 3:47pm
The shape of the omnitop 212 is just a variation on a very basic 2x12 horn that has been used for a long time. The thing that is really something unique is the melded tweeter array.
Vert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Vert Quote  Post ReplyReply Direct Link To This Post Posted: 19 January 2013 at 9:39am
shot of the melded tweeter array on my DRs
Box builder, pm for quote
fordlltwm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordlltwm Quote  Post ReplyReply Direct Link To This Post Posted: 20 January 2013 at 2:15am
I'm considering buying the plans for the omnitops, but I'm wondering whether anyone knows of a cheaper driver that will work instead of the rather expensive deltalites?
Cheers
ELV-500
Marshall 6040
Inkel MX-1402
And a worrying amount of 100v line horns
michalb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michalb Quote  Post ReplyReply Direct Link To This Post Posted: 20 January 2013 at 4:26pm
Hi I build my omni tops with the Beta 12 driver. They might not have the output of the more expensive drivers but 2 a side will hit 127db with 200w rms per driver.
http://www.eminence.com/pdf/Beta_12A.pdf
hope this helps
Michal
Audio_AL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Audio_AL Quote  Post ReplyReply Direct Link To This Post Posted: 20 January 2013 at 4:50pm
The least expensive recommended driver is the Eminence Beta 12. A high
performance alternative is the Delta Pro 12. For lighter weight, albeit at a cost, use
a neo magnet driver, such as the Eminence Basslite 2012, Deltalite II 2512 and
Kappalite 3012HO.
Make it loud!
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordlltwm Quote  Post ReplyReply Direct Link To This Post Posted: 20 January 2013 at 5:20pm
Cheers, that looks rather more affordable, may go and shoot some $$'s at his site.
ELV-500
Marshall 6040
Inkel MX-1402
DiscoFish View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiscoFish Quote  Post ReplyReply Direct Link To This Post Posted: 20 January 2013 at 5:35pm
Very nice work, love this style of cab. Bet they sound lovely Thumbs Up
Sam Owen
S.P.O Sound & Lighting
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordlltwm Quote  Post ReplyReply Direct Link To This Post Posted: 20 January 2013 at 8:56pm
And in even better news, a friend of mine who works as a carpenter is willing to knock em from off cuts for a couple of pints :D
ELV-500
Marshall 6040
Inkel MX-1402
nuclearbass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nuclearbass Quote  Post ReplyReply Direct Link To This Post Posted: 20 January 2013 at 10:46pm
My omnitops, they have some kind if phase bung infront if the driver which you cnt really see from this pic
one life - have fun!
Force fusion pro audio
