My SMT212 CP755TI / SN12B |
Post Reply | Page <1 34567 9> |
wafflesomd
Young Croc Joined: 21 September 2007 Status: Offline Points: 811 |
I do plan on porting them. I was talking to a friend of mine, and he stated that buy design, the cabinet will resonate at 400-500hrtz. I guess I'm going to hold out until I get some proper drivers. I'd like to see some measurements with some Delta's, or other drivers. I really can't stand resonance at all. I havn't purchased any new drivers yet. Seems like the only driver that has been proven to work well is the p.audio sn12b. That driver is far to expensive. I can't find another driver with even close specs. It seems like the x12 might be a better solution for me. I'm not looking to spend huge amounts of money on drivers.
Edited by wafflesomd - 06 November 2008 at 8:32am |
Tekasis
You tried looking at the Celestion Truvox series ?
**Heavy Weight-Line**
A home without books is like a body with no soul. |
wafflesomd
I'm not sure how well those would work. The specs are close the Emeinence beta and delta.
Deadbeat
wafflesomd - you also need to look at polars, FR graphs, etc to determine breakups and beaming and is essential in selecting xover point. This gives you a clearer picture.
' I was talking to a friend of mine, and he stated that buy design, the cabinet will resonate at 400-500hrtz. I guess I'm going to hold out until I get some proper drivers. I'd like to see some measurements with some Delta's, or other drivers. I really can't stand resonance at all. ' What was he talking about? Any reasoning you could enlighten us with?
Edited by Deadbeat - 06 November 2008 at 8:38pm |
Away on extended leave.
wafflesomd
He based this on the fact that the bottom, and piece F are parrellel and don't expand. I probably said that wrong.
Do emeinence have polar measurements? Edited by wafflesomd - 06 November 2008 at 8:49pm |
Deadbeat
Haha. In that case all our speakers are flawed.
Anyway. Tell your friend that he is right in noticing standing waves in a cabinet caused by parallel sides. The distance from Piece F to the bottom is 680mm. This is the wavelength of 500hz - he's done the math right. Unfortunately, the driver's chassis and cone are in the way of nary a standing wave . Besides - any standing waves formed would be chased away if you stuffed and lined the boxes properly when finished.
wafflesomd
Neato.
So how would I go about stuffing and lining these?
Deadbeat
An average 12" begins to start being directive (beaming) at 1k2. Most manufacturers will give you polar plots at several frequencies. I don't think eminence do. If you wanted to be absolutely sure any standing waves were absorbed - I'd staple a thin layer of closed cell to the top and bottom of the chamber. Edited by Deadbeat - 06 November 2008 at 8:55pm |
wafflesomd
The rear chamber, the waveguided section, both?
Deadbeat
Just the rear chamber where your friend is mortally afraid of resonance. Top and bottom. Closed cell. Thin layer. Staples.
wafflesomd
Thanks for the help.
Now it just comes down to driver selection. Using a 3 way design would be the most cost effective thing to do. Most 2" are very, very expensive, and the horns are as well.
Edited by wafflesomd - 06 November 2008 at 9:09pm |
Deadbeat
What's your budget for the whole lot?
