  New Posts New Posts RSS Feed - TH-Mini - tapped horn  - by Danley Sound Labs
 Post Reply Post Reply Page  <1234 12>
jethrocker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jethrocker Quote  Post ReplyReply Direct Link To This Post Posted: 12 June 2009 at 5:07am
Interesting TDA... how does it sound..any measurements or even just simmed response?
edit: OP name confusion.
Edited by jethrocker - 12 June 2009 at 10:19pm
S.A.L.S.A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote S.A.L.S.A Quote  Post ReplyReply Direct Link To This Post Posted: 12 June 2009 at 3:09pm
How are the results in comb. with the NEXO LS1200 sub??
Does it goes louder and deeper??
Nice bin!
Dave
Get to the Point with L'acoustics Dv-Dosc!
bitzo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bitzo Quote  Post ReplyReply Direct Link To This Post Posted: 12 June 2009 at 3:22pm
I think he doesn't use this bin in combo, probably he has stacked on a nexo to facing the external dimension. Just IMHO
Ibex View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ibex Quote  Post ReplyReply Direct Link To This Post Posted: 13 June 2009 at 10:20am
Very nice!!!
TDA, which driver do you use in your cab?
How does it sound?
Did you make a comparison to the original th mini?
Does your design play deeper or loeder than the one from tom?
Measurements would be very interesting!
TDA-Audio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TDA-Audio Quote  Post ReplyReply Direct Link To This Post Posted: 15 June 2009 at 9:32pm
inside 18" version
Post Options Post Options   Thanks (0) Thanks(0)   Quote jethrocker Quote  Post ReplyReply Direct Link To This Post Posted: 16 June 2009 at 6:59am
Very nice ... but we still want answers :)
Ibex View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ibex Quote  Post ReplyReply Direct Link To This Post Posted: 16 June 2009 at 7:11am
Seems that TDA's real intention is to give us some philosophic thoughts Wacko
Although i'm as well very strained to get some auditory impressions from TDA corresponding on the 12" and the 18" modified tapped constructions.
Edited by Ibex - 16 June 2009 at 7:50am
Father-Francis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Father-Francis Quote  Post ReplyReply Direct Link To This Post Posted: 16 June 2009 at 8:21am
TDA write in Russian we will translate , no worriesThumbs Up I´l speak for some of us we getting more outernational Big smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote TDA-Audio Quote  Post ReplyReply Direct Link To This Post Posted: 16 June 2009 at 3:39pm
Quote
...seems that you know each other?
yes . I Max Peshkov has reported on forum
Quote TDA, what do you as a pro-engineer think about my point of view on the miscellaneous cab designs? Where is the leak in my assumption? Why aren't the responses congruent?
18" version - full still Staip
12" version - recalculated ....
i used
I am a test driver"s -
p-audio p-120\130Lf
B&c 12nw100
Ciare 12.00sw
Beyma 12Lx60
P-Audio SD-12EL
and 18"
18lw1400
18tbx100
18" cabs  - good pressure, but big weight.. (for 18tbx100).
18lw1400 - no good work..
12"cab - ciare - very big pressure!!
12"nw100 - good, but much loses ciare...
12LX60 - Very Good.
SD-12EL - good.
12 versions -preference...small size! and good pressure for their own size
Tapped Horn and Scoop"s - different cabs ...
Edited by TDA-Audio - 17 November 2009 at 8:36pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote TDA-Audio Quote  Post ReplyReply Direct Link To This Post Posted: 16 June 2009 at 3:50pm
Quote How are the results in comb. with the NEXO LS1200 sub??
LS1200 vs TH 12"
12" 48hz -6 db.
ls-1200  32hz -6db
pressure
th-12" vs LS1200 (street)
for 1 m - ls1200 more pressure
but 15-20m - TH-12" vs Ls1200 -  approximately equally pressure..
Ibex View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ibex Quote  Post ReplyReply Direct Link To This Post Posted: 16 June 2009 at 9:30pm
First of all: TDA, thanks for answering!
p-audio p-120\130Lf
B&c 12nw100
Ciare 12.00sw
I think the 12NW100 has the same parameters as the 12PS100 but with neodym instead of ferrite?
Isn't the response of the 12" version loaded with the Ciare a little bit peaky in comparison to the B&C? Did you annoy the minimum at 80Hz when you were listening to music and/or made your comparison/measurements?
That is, what the simulation says:
Staiper Design by TDA - Ciare 12.00SW vs. B&amp;C 12PS100 - SPL
black = B&C 12PS100
grey = Ciare 12.00SW
Ibex View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ibex Quote  Post ReplyReply Direct Link To This Post Posted: 17 June 2009 at 6:05pm
and 18"
18lw1400
18tbx100
TDA, i'm not able to reconstruct what you said, my results are nearly congruent with both drivers...
Confused
Staiper Design - B&amp;C 18TBX100 - Hornresponse Input Data
Staiper Design - 18Sound 18LW1400 vs. B&amp;C 18TBX100 - SPL
black = 18Sound 18LW1400
grey = B&C 18TBX100
This page was generated in 0.111 seconds.
