  New Posts New Posts RSS Feed - Powering MT122s
Powering MT122s
dangleberries View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dangleberries Quote  Post ReplyReply Direct Link To This Post Topic: Powering MT122s
    Posted: 14 June 2005 at 7:12pm
Hi, I've starting building two cabinets for Porn Horns, gonna load them with 2 x SN12B's & 1 SD740N.
As soon as they're working I'lll be starting on another two. Any suggestions on what I could power them with? Are any of the Void amps from proaudioparts suitable?
Thanks - The Dangleberry
Post Options Post Options   Thanks (0) Thanks(0)   Quote dangleberries Quote  Post ReplyReply Direct Link To This Post Posted: 25 June 2005 at 11:20am
Is everyone on holidays or what? Surely someone has Mt122s with Porn Horns?!? What are you powering them with???
Is it cos I is a dangleberry?
bigmike216 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigmike216 Quote  Post ReplyReply Direct Link To This Post Posted: 26 June 2005 at 8:49pm
Might have better luck in the porn horn section
Dom View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dom Quote  Post ReplyReply Direct Link To This Post Posted: 27 June 2005 at 1:54pm
Any amp rated at 600-1200W into 4 ohms for the 12 inchers.
Any amp rated at 80-160W into 8 ohms for the compression driver.
How much power you need to put into them will kind of depend on how much bass you have underneath them.
How much you want to spend is probably a deciding factor as well...  Not much point recommending a rack full of MC2 amps if you budget says behringer...
Maybe you didn't get many answers as the question was a bit vague to start with.
If it's any help we power the 12"s with a QSC PLX 3402 and the compression drivers with a Chevin Q6.
There are plenty of amps that will do the job.  You won't go far wrong if you pick something from a reputable manufacturer that is in the ball park with power ratings though.
"It sounded like a million fire engines chasing ten million ambulances through a war zone and it was played at a volume that made the empty chair beside me bleed."
