  New Posts New Posts RSS Feed - Super Bass Horn V.02 by Startec (Quad Acoustics-F)
 Post Reply Post Reply Page  <1 34567 46>
dj-panoramix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dj-panoramix Quote  Post ReplyReply Direct Link To This Post Posted: 28 October 2008 at 8:28pm
Originally posted by boycey boycey wrote:
i only ask about the v18 because i have a pair
ok ,so if the question was ,is there any mesurement done with void ,i say no. only simulation had been made with pd and void.
the only driver had been tested enough in real life is the rcf.
as i allready said ,this is an more than ten years old product and have been made specially for a phl oem driver ,and now as he get many peoples asking for a big horn he reworked on it to go with the rcf speaker.
Edited by dj-panoramix - 28 October 2008 at 8:31pm
mykey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey Quote  Post ReplyReply Direct Link To This Post Posted: 29 October 2008 at 4:03am
I'll put this in HR and see what's cooking
tomschute View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomschute Quote  Post ReplyReply Direct Link To This Post Posted: 29 October 2008 at 11:53am
Quote will at the moment i will stick to the existing DIY plans here for the midtops..
so is there 2 different 3 way tops he's designed ? sorry a bit confused... and plans for a diy one then?
so for the impatiants just nice looking cabs!
and as deadbeat asked, has he phase plugged a co axil driver?
www.stableaudio.co.uk
Speaker Building Services
Xmax extreme View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Xmax extreme Quote  Post ReplyReply Direct Link To This Post Posted: 29 October 2008 at 12:01pm
nope mate, im referring to the existing plans here at speakerplans, the porn horns, the MT122Smile
Maximum Excursion
Don't criticize your own competition, it looks like a publicity of your own commercial products.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomschute Quote  Post ReplyReply Direct Link To This Post Posted: 29 October 2008 at 6:35pm
i see Embarrassed
Post Options Post Options   Thanks (0) Thanks(0)   Quote Xmax extreme Quote  Post ReplyReply Direct Link To This Post Posted: 30 October 2008 at 3:38am
i see Embarrassed
Wink
Maximum Excursion
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey Quote  Post ReplyReply Direct Link To This Post Posted: 30 October 2008 at 12:31pm
with th RCF driver 2.0 x pi
0.5 x piShocked
''112 dB 1/w/m 3ohz à 125 Hz à -6 dB"
Edited by mykey - 30 October 2008 at 12:47pm
DJEvol View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DJEvol Quote  Post ReplyReply Direct Link To This Post Posted: 30 October 2008 at 8:20pm
Hello i'm french and my english is very bad
Thanks at Panoramix for dévoiled this plan here
The SBH 112dB/1W is for 4 cabinet!! Staked
I speak often with Startec
_djk_ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote _djk_ Quote  Post ReplyReply Direct Link To This Post Posted: 31 October 2008 at 1:32am
Too small of a mouth, needs a chamber in front of the driver.
djk
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey Quote  Post ReplyReply Direct Link To This Post Posted: 31 October 2008 at 3:28am
@DJK
thats why I originaly was a bit shocked at it's 'not so big size'
in the photo it looked enormous, so i thought...yeah that will do the business, then I worked out its size from the drawing and wondered how how it would sim
because a horn with a 3 meter length could do with a bigger mouth
it's still doing the business at 30 though
Post Options Post Options   Thanks (0) Thanks(0)   Quote _djk_ Quote  Post ReplyReply Direct Link To This Post Posted: 31 October 2008 at 9:06am
This is one horn in 0.5Pi (could be 4 horns in 2Pi):
Note the 18L front cavity, and no dip?
Mouth about 6400cm^2, 80cm (31.5") square.
Subtract 29dB for 2.83V/1M, or 117.2dB/2.83V/1M. This is sensitivity, the horn is actually 4R at the sample frequency, so its real efficiency is only 114dB/W/1M.
Edited by _djk_ - 31 October 2008 at 9:13am
djk
Post Options Post Options   Thanks (0) Thanks(0)   Quote dj-panoramix Quote  Post ReplyReply Direct Link To This Post Posted: 31 October 2008 at 12:04pm
explain a little beat more pleaz ?
if you can do this design better ,do it ,i will show to the designer to see what he think.
thanks for the simulation.
