JL Slot port design - Does size matter? |
Discogimp
Joined: 13 February 2006 Location: United Kingdom Status: Offline Points: 76 |
Topic: JL Slot port design - Does size matter?Posted: 04 November 2008 at 10:42pm |
I been faf'n around with a 500/1 & JL 10W7 in what is meant to be a ported box made to jl spec but has been made in a wedge shape so not sure if it is or isn't jl spec
spose i can get the tape on it and work the volume out.
But that's not the question, i need to build a new cab to fit in the larger space i have
and working with a little program i've got the optimum size would be a 3.4 ft3 ported box
which seems to give a 3 db rise from 50 Hz down 6 db rise at 35 Hz!!!
The question is......is it worth making a box that large when i can make the jl
sloted port box at only 1.5 ft3? and do the above rise levels sound true?
Any body got any software to work that out?
cheers - Pete
Nuf-Func Disco Devices
imageoven
Joined: 28 March 2007 Location: Scotland Status: Offline Points: 2199 |
Posted: 05 November 2008 at 9:02am |
sounds to me like you need "winsid" - search for that and you should do ok.
LunchieTey
Joined: 06 February 2005 Location: Australia Status: Offline Points: 934 |
Posted: 14 November 2008 at 8:23am |
That's a big box for a car audio 10", they are designed for small boxes(loose suspension) and may suffer if it's too big. Just plot a xmax plot on win isd to see if you're needing a subsonic filter. The rise is perfectly acceptable, its a sub driver, not a prosound driver! Don't forget the car will increase volume below around 70hz at 12db/oct too
Speaker addict
