ES18-BPH |
Post Reply | Page <1 3132333435> |
UpComingSound
Registered User Joined: 21 June 2006 Location: United States Status: Offline Points: 393 |
will the B&C 18NBX100 work good in this cabinet
SpeakerFreaker0181
Registered User Joined: 22 April 2015 Status: Offline Points: 13 |
Somehow my es18bph cabinets make a rambling sound when I turn up the volume. I am trying to figure out what causes this rambling sound. I already put extra screws in some places in order to try to resolve my problem but I still haven't been able to resolve the issue.
Can anybody give me some advice on how to fix this? Would love to not have this rambling sound. I have 4 ES18BPH cabs loaded with PD186 powered by a Crown Macrotech 3600vz and a Xilixa xp4080 for processing.
Hemisphere
So you're having identical issues with all 4 es18 and both hogs??
Obviously it's possible you're just a shoddy builder (and if your builds are shoddy you probably know it), but as you say you're experiencing the problem universally there may be some other fault in the chain, so make sure to examine each stage carefully, including drivers, amps, processing, progrsam material cables and test environment. Replace every stage one by one with a control if you can. How good are your cuts? Any air gaps in the joins? Any visibly uneven joins in critical places? |
msoundsystem
Young Croc Joined: 10 November 2011 Location: wales Status: Offline Points: 625 |
Whats your hpf and lpf set at?
Hz so good
Registered User Joined: 04 September 2017 Location: Unknown Status: Offline Points: 47 |
thanks in advance
but any way you can get one double es18 cab from 2 boards, Just realised this thread is almost a decade old!!! |
SpeakerFreaker0181
I managed to fix this a while back. It turned out that the cause was that I only used 4 screws for the access panel F, one in each corner. Obviously this wasn't enough to hold the pressure my PD186's are creating... I added about 16 screws or so, rattling was gone. Big relief.
They sound sweet now! As for the hogs, I removed the top panel and glued all of the joints on the inside. Should have done that before, lesson learned. I also added screws at the joints on the inside. After putting back the top panel the rattling sound was fixed as well for the hogs. BIG relief. This were my first bandpass horn and scoop builds, before I only built 3 bass reflex boxes. These subs sound awesome! Especially the hogs, they are brutal :) Thanks for the advice!
It's all about the bass!
tv00
Yes speakerboxes needs to be REALLY well glued & screwed.
All good builts are made with dadoes / routed out recessed joints ... |
Hemisphere
Great to hear it, and thanks for posting the update. Next time someone comes with the same problem hopefully we'll be better placed to advise.
tv00
Sorry, wrong thread :-(
Edited by tv00 - 08 January 2018 at 11:06am |
Hemisphere
Just noticed the ES stands for Ercegovic Stipe
Tonskulus
Thinking of building 6-8 of these for psytrance outdoor parties. Looks much like turbosound tsw bandpass horns, so might just be good enough as a stand alone bass horns when stacked.
I really need very loud chest thumping bass for our parties - but not being too heavy system. Any other options? |
You definitely want a proper sub under them for psytrance
