Do you know this Project from Beyma ? |
Page 123 7> |
| Author | ||
KenTech
Joined: 05 December 2006 Status: Offline Points: 133 |
Topic: Do you know this Project from Beyma ?Posted: 30 June 2009 at 9:47pm |
Hi everyone.
I;ve discovered a project from Beyma. SB15-1 http://www.prescomaudio.com/webadmin/documents/15p80nd_subbass.pdf But, i don't know this data... ![]() I want to build 2 cabs. Those missing data are stoping me to do that. Can u help me ? anybody... |
Ibex
Posted: 30 June 2009 at 10:01pm |
Maybe this could help you...
![]() Do you have an equipment to measure the cabs when you have finished them? Would be interesting to me! THX! greez |
KenTech
Posted: 30 June 2009 at 11:02pm |
thanx a lot mate !! to measure what ? Frecvency response ? weight ? dimensions ? what ?
space-face
Joined: 11 September 2008 Location: E5 Status: Offline Points: 439 |
Posted: 01 July 2009 at 2:28am |
Looks good not really seen anything like it before. Would be interested in hearing a few. It's like a tapped horn but with a compression chamber... I guess that would make it act more like a scoop but the driver is way down the horn mouth. hmmm
Edited by space-face - 01 July 2009 at 2:39am |
Ibex
Posted: 01 July 2009 at 6:56am |
By now there exist a lot of thess design. Most name it bass-hybrid, some also say ARLS (advanced reflex tuned sub)... the design works more like a reflex cab, because of the relativ big chamber, but it also bears resemblance to a tapped horn, which can be recognized with its two peaks in the frequency response, cause the driver is mounted inside the hornloaded reflex port. this design has a better effiency than a conventional reflex loaded one.
![]() black = Beyma SB18-1 - 18P1200Nd
grey = Beyma SB15-1 - 15P1200Nd
Ibex
Posted: 01 July 2009 at 6:59am |
chum, the frequency response! wich driver will you use in this cab?
greez
KenTech
Posted: 01 July 2009 at 8:13am |
i'm thinking of Paudio's SD15 if i have the money i need. If i don't, maybe i will try SM115K from beyma, or Selenium 15PW6.
does anyone have the database for Horn resp for this Enclosure ? 10x |
Ibex
Posted: 01 July 2009 at 8:20am |
This is the HR input for 1 Beyma SB15 cab loaded with Beyma 15P1200Nd in half space...
![]() cheers
KenTech
Posted: 01 July 2009 at 8:23am |
thanx a lot !!!
KenTech
Posted: 01 July 2009 at 8:48am |
here. I;ve simulated Beyma SM115K and Paudio SD15
Blak: SD15 Grey: Sm115K This doesn't look like the simulation above, where is simulated a SB15-1 Cab and a SB18-1 Cab.... Why ? ![]() |
bitzo
Joined: 20 November 2007 Location: Italy Status: Offline Points: 977 |
Posted: 01 July 2009 at 8:49am |
this design don't have any braces but it's also so compact. Someone have ever heard/built this cab?
Should be suitable for kick section over scoops? Before someone says go for hd15/hd18, I hate access port . |
KenTech
here. I;ve simulated Beyma SM115K and Paudio SD15 Blak: SD15 Grey: Sm115K This doesn't look like the simulation above, where is simulated a SB15-1 Cab and a SB18-1 Cab.... Why ? ![]() Edited by KenTech - 01 July 2009 at 8:51am |
Page 123 7> |
