  New Posts New Posts RSS Feed - Do you know this Project from Beyma ?
KenTech View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenTech Quote  Post ReplyReply Direct Link To This Post Topic: Do you know this Project from Beyma ?
    Posted: 30 June 2009 at 9:47pm
Hi everyone.
I;ve discovered a project from Beyma. SB15-1
http://www.prescomaudio.com/webadmin/documents/15p80nd_subbass.pdf
But, i don't know this data...
I want to build 2 cabs. Those missing data are stoping me to do that. Can u help me ? anybody...
Ibex View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ibex Quote  Post ReplyReply Direct Link To This Post Posted: 30 June 2009 at 10:01pm
Maybe this could help you...
Beyma SB-15
Do you have an equipment to measure the cabs when you have finished them? Would be interesting to me!
THX!
greez
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenTech Quote  Post ReplyReply Direct Link To This Post Posted: 30 June 2009 at 11:02pm
thanx a lot mate !! to measure what ? Frecvency response ? weight ? dimensions ? what ?
space-face View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote space-face Quote  Post ReplyReply Direct Link To This Post Posted: 01 July 2009 at 2:28am
Looks good not really seen anything like it before. Would be interested in hearing a few. It's like a tapped horn but with a compression chamber... I guess that would make it act more like a scoop but the driver is way down the horn mouth. hmmm
Edited by space-face - 01 July 2009 at 2:39am
Ibex View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ibex Quote  Post ReplyReply Direct Link To This Post Posted: 01 July 2009 at 6:56am
By now there exist a lot of thess design. Most name it bass-hybrid, some also say ARLS (advanced reflex tuned sub)... the design works more like a reflex cab, because of the relativ big chamber, but it also bears resemblance to a tapped horn, which can be recognized with its two peaks in the frequency response, cause the driver is mounted inside the hornloaded reflex port. this design has a better effiency than a conventional reflex loaded one.
Beyma SB15-1 vs. SB18-1 - SPL
black = Beyma SB18-1 - 18P1200Nd
grey = Beyma SB15-1 - 15P1200Nd
Ibex View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ibex Quote  Post ReplyReply Direct Link To This Post Posted: 01 July 2009 at 6:59am
chum, the frequency response! wich driver will you use in this cab?
greez
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenTech Quote  Post ReplyReply Direct Link To This Post Posted: 01 July 2009 at 8:13am
i'm thinking of Paudio's SD15 if i have the money i need. If i don't, maybe i will try SM115K from beyma, or Selenium 15PW6.
does anyone have the database for Horn resp  for this Enclosure ?
10x
Ibex View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ibex Quote  Post ReplyReply Direct Link To This Post Posted: 01 July 2009 at 8:20am
10x
This is the HR input for 1 Beyma SB15 cab loaded with Beyma 15P1200Nd in half space...
Beyma SB15-1 - Hornresponse Input Data
cheers
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenTech Quote  Post ReplyReply Direct Link To This Post Posted: 01 July 2009 at 8:23am
thanx a lot !!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenTech Quote  Post ReplyReply Direct Link To This Post Posted: 01 July 2009 at 8:48am
here. I;ve simulated Beyma SM115K and Paudio SD15
Blak: SD15
Grey: Sm115K
This doesn't look like the simulation above, where is simulated a SB15-1 Cab and a SB18-1 Cab....
Why ?
bitzo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bitzo Quote  Post ReplyReply Direct Link To This Post Posted: 01 July 2009 at 8:49am
this design don't have any braces but it's also so compact. Someone have ever heard/built this cab?
 Should be suitable for kick section over scoops? Before someone says go for hd15/hd18, I hate access port Angry.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenTech Quote  Post ReplyReply Direct Link To This Post Posted: 01 July 2009 at 8:49am
Blak: SD15
Grey: Sm115K
Why ?
Edited by KenTech - 01 July 2009 at 8:51am
This page was generated in 0.143 seconds.
