  New Posts New Posts RSS Feed - Porn horn crossover points
levyte357 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Topic: Porn horn crossover points
    Posted: 22 December 2005 at 5:14pm
Please forgive me if  have missed this in earlier posts...
Assuming specified P.audio driver is mounted "correctly" in smallest rear chamber possible, with the 740 CD on specified horn, what are the crossover points for this kinda mid top?
Thought I saw 130 and 10K somewhere, but shirley I'm wrong...
Thanks in advance...
Please don't flame... I don't smoke..... well.
Tom Umney View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom Umney Quote  Post ReplyReply Direct Link To This Post Posted: 02 January 2006 at 2:33pm
http://www.proaudioparts.co.uk/pornhorn.asp
It is 130hz-2.5khz for the 12 inch porn horn and 2.2khz-20khz for the 1.5 inch porn horn.
tendril View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tendril Quote  Post ReplyReply Direct Link To This Post Posted: 30 January 2006 at 2:32pm
I have heard a whisper that Loophole was  setting his x-over point higher than 130 because of performance problems. However, his dutty box is full so I can't pm him to find out all the details.
Tendril
A mistake is a mistake only if one learns nothing from it.
loophole View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote loophole Quote  Post ReplyReply Direct Link To This Post Posted: 30 January 2006 at 2:55pm
cleared my inbox now
i generally run mine at 150, cos the hd's will play hat high comfortably, and it allows me to push the porns that bit harder. its not so much that they wont play to 130, but that the hd's sound better at that freq, and take a lot of the strain off the mids
Post Options Post Options   Thanks (0) Thanks(0)   Quote tendril Quote  Post ReplyReply Direct Link To This Post Posted: 30 January 2006 at 3:59pm
You use them over hds? Have you heard them over 1850s?
Tendril
pooju View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pooju Quote  Post ReplyReply Direct Link To This Post Posted: 20 August 2006 at 1:43pm
loophole how high do you play the twelves? the plot on here seem to give different ideas
Post Options Post Options   Thanks (0) Thanks(0)   Quote loophole Quote  Post ReplyReply Direct Link To This Post Posted: 23 August 2006 at 1:13pm
i havent heard them over 1850's alone. i use them above hd15s. i cant see any reason they wouldnt sound fine though, disjunkt use their 1850s right up to 200 to cross to phillies (bit dodge IMO, but sounds good enuff) and thats more than high enough for porns..
its been ages since ive had the system out, but i usually play my 12's up to 2.1 if im remembering right - i find they need a 6 or 12db slope eq'ed up from about 1.4k though, as well as a 2.5db-ish dip around 600. there's usually one more eq on the mids to get them sounding sweet, but beyond these first main two, room acoustics dominate...
