Actually Building a PC |
Post Reply | Page <1 2345> |
Author | |||
Saul
Nice one ham, i look foward to hearing some fresh tunes out of it.
bassmish
Young Croc Joined: 28 October 2007 Location: MAAAANCHESTER Status: Offline Points: 1333 |
might be a while. loads of programs don't work with windows 64 bit??? very annoying, had to find 'alternative' downloads for loads of things, including msn messenger!!!?.... what the hell
it's damn fast tho! |
odc04r
Try pidgin as a replacement for msn messenger, you won't go back to the ad loaded crapfest that is the official msn client.
I do not know if there is a 64 bit compatible version but I expect there is. |
bassmish
I managed to find a version for 64 bit but it's pretty annoying. got other problems with other programs as well tho that's I('m finding harder to fix. now trying to remember why I'm using 64 bit!!
subbass
windows 7 64 bit?
All my 32bit programs work with it! Including Proengineer, which if it has an opportunity to break .. will
Edited by subbass - 21 January 2010 at 8:12pm |
Humble Tafari
Registered User Joined: 26 November 2006 Location: United States Status: Offline Points: 562 |
Just be careful when inserting the processor. It can only go in one way. And if your forcing it, then it is not lined up correctly. Having a good pair of eyes and/or Magnifying glass dome can be helpful.
Oh....and did i say, be very careful when inserting the processor. Same applies to the Ram boards. respeks. PS, i personally never used an anti-stataic wriststrap. But i guess its good to have.
bassmish
xp |
bassmish
done it already, she's up and running. but thanks for the advice all the same. the cooler bit that sits on top of the processor looked like a jet engine. was well cool. has loads of copper pipes on it and looks like it could be some kind of crazy water cooling system |
subbass
windows 7 64 bit would have been my best bet - I've never had good luck with XP64.. Good luck with it - /should/ all be working fine, why not go for 32bit windows? As far as i know, XP64 was never really used that much......
joshd963
Registered User Joined: 09 September 2009 Status: Offline Points: 375 |
only problem that may occur to general users when using 32bit is that the max RAM is 3.25gb
Spesh
Old Croc Joined: 15 July 2007 Location: Surrey Status: Offline Points: 1606 |
Not if you enable memory hole remapping.
But I see what you're saying. 32 bit OS's only support up to 4GB's of RAM. Shouldn't really be a problem for most people though.
odc04r
This x(a lot). Never had any joy with xp 64, far too much hassle to get apps for it. You will be wanting windows 7 or 64 bit Ubuntu tbh. |
