  New Posts New Posts RSS Feed - X1 under 1850 horn and mt122
adyk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote adyk Quote  Post ReplyReply Direct Link To This Post Topic: X1 under 1850 horn and mt122
    Posted: 27 July 2010 at 9:22pm
Hi am i mad to build two letterbox X1 to go under my stack of 4 1850 horns and 2 MT122.? I also want to use them on a smaller stack but will they work with the first stack?
Your thoughts pleaseConfused
Samson Sounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Samson Sounds Quote  Post ReplyReply Direct Link To This Post Posted: 05 August 2010 at 9:49pm
What styles of music will you play through them?
Samson Sounds
AM55 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AM55 Quote  Post ReplyReply Direct Link To This Post Posted: 05 August 2010 at 10:38pm
I would advise against it.
The 1850 is designed as a one way bass solution, the X1 is designed as half of a 2 way bass solution. You can of course use the 1850 to be the other half of the 2 way bass solution but its not ideal. If you want to go to the trouble of 2 way bass then its worth while picking cabs that will excel in there dedicated frequency band, hd15's or USB's work very well with X1's
Just build or buy more 1850's. Remember the more you add the lower the group will drop.
adyk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote adyk Quote  Post ReplyReply Direct Link To This Post Posted: 05 August 2010 at 10:57pm
Thanks for the reply, im using the system for mainly dance music, IE psy trance, hard trance, house, electro, tech etc.
If i build two more 1850's will my mt122 cope with 6 1850's?
Ady
AM55 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AM55 Quote  Post ReplyReply Direct Link To This Post Posted: 05 August 2010 at 11:12pm
For that type of music 1850's are ideal and X1's aren't required.
They will keep up if they are loaded with good drivers and amped properly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Samson Sounds Quote  Post ReplyReply Direct Link To This Post Posted: 10 August 2010 at 7:44am
Yea, for that kind of music, I wouldnt bother with X1s, unless you have really subby psytrance (like Infected Mushroom - Noise Maker), but then you would need a lot more X1s to hear much of a difference in the response.
Samson Sounds
Spesh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Spesh Quote  Post ReplyReply Direct Link To This Post Posted: 10 August 2010 at 10:20am
+1 on not building X1's. The 1850 horn was pretty much designed specifically for the styles of music that you play.
Symmetry Soundsystem
Alimon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alimon Quote  Post ReplyReply Direct Link To This Post Posted: 27 August 2010 at 1:01am
what hz would 2 letterbox x1's drop? and do they have a rumbly sound like the phycos. just thinking cause we have 8 1850's perfect for house etc. propper punchy but for jungle, breakcore etc. dont have the ideal rumble for it? so 2 letterbox x1's under 4 1850's either side? good idea or not?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alimon Quote  Post ReplyReply Direct Link To This Post Posted: 27 August 2010 at 1:02am
Meat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Meat Quote  Post ReplyReply Direct Link To This Post Posted: 27 August 2010 at 1:56pm
Why not just hire some and try them? Depending on where you are could be a plan. You'd probably need at least 8 to go with that pile so not a cheap outlay. Try it first, if it gives you the sound you want then go for it.
adyk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote adyk Quote  Post ReplyReply Direct Link To This Post Posted: 11 September 2010 at 4:51pm
thanks all for your help but i think im gonna build 4 more 1850 unless you know of any for sale.
adyk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote adyk Quote  Post ReplyReply Direct Link To This Post Posted: 11 September 2010 at 6:08pm
Smile
