  New Posts New Posts RSS Feed - Amp Internals 2
Amp Internals 2
 Post Reply Post Reply Page  <1 230231232233234 260>
Post Options Post Options   Thanks (0) Thanks(0)   Quote Earplug Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2020 at 9:56am
"Switched it on and something went BANG "
That sounds about right for those modules as well!  LOL
One company here used the 500A and 1000A modules to power a range of speakers they brought out. They never lasted very long - especially the sub cabs, that blew up very quickly. They then did a deal with RAM to manufacture modules for them, which were (marginally) better.   Ermm
Post Options Post Options   Thanks (0) Thanks(0)   Quote kedwardsleisure Quote  Post ReplyReply Direct Link To This Post Posted: 25 June 2020 at 11:48am
Citronic-badged PRO3200
Not sure the quality of the fuse-changing fills me with confidence!
Edited by kedwardsleisure - 25 June 2020 at 1:22pm
North Staffordshire
HonkyJones View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote HonkyJones Quote  Post ReplyReply Direct Link To This Post Posted: 25 June 2020 at 1:51pm
I found this Leak Stereo 20 on the Russell Technologies website. Read some of the engineer's commentary LOL He's a funny guy! Some more internals on there too, enjoy!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbl_man Quote  Post ReplyReply Direct Link To This Post Posted: 26 June 2020 at 9:27am
Is that potting compound or just black splodge all over that driver board Kevin? How the hell is anyone spose to repair that?
Edit....quite liking the heatsink though,very artistic! Smile
Edited by jbl_man - 26 June 2020 at 9:31am
odc04r View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote odc04r Quote  Post ReplyReply Direct Link To This Post Posted: 26 June 2020 at 9:43am
Looks like potting compound, maybe the manufacturer had problems with vibration on those components or shorting due to dust, then rather then redesign everything the boards got potted to make the problem go away. Or it could be linked to temperature sensing.
M4trix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote M4trix Quote  Post ReplyReply Direct Link To This Post Posted: 26 June 2020 at 9:05pm
Maybe to prevent or make it harder for the reverse engineers. Wink
Edited by M4trix - 26 June 2020 at 9:07pm
Wikl109 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wikl109 Quote  Post ReplyReply Direct Link To This Post Posted: 26 June 2020 at 9:56pm
Honky Jones, can I just say you made my day by linking to this guys website. This quote regarding the Crown DC300A really made me smile:
"Check out this bollocks of a switch. It's designed so that the thin metal sides cut through the soft plastic rocker every time it is operated. It is about to pop apart and spill its guts. It is mounted so that it can't be removed without taking half the works out. It is a weird shape and size so I can't replace it with a proper one. I like to imagine that the designer of it is no longer with us, having died in a bizarre accident.
Fixing this is going to be the time-consuming bit of the operation."
Classic.
Cheers, Chris.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kedwardsleisure Quote  Post ReplyReply Direct Link To This Post Posted: 27 June 2020 at 10:23am
Potted with something very hard, they must've learned it from powersoft. All in the airflow so got to be for protection from dust and moisture.
Either way the thing's scrap!
North Staffordshire
JJax View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JJax Quote  Post ReplyReply Direct Link To This Post Posted: 01 July 2020 at 7:54am
Tasso TD-8000
Class TD. Power amps look to be Lab.Gruppen copies.
Manufacturer claims:
2x 1300W @ 8ohm
2x 2300W @ 4ohm
2x 3200W @ 2ohm
3900W @ 8 ohm bridge
4900W @ 4 ohm bridge
ACM M2500
When life gives you lemons, sell them and use the money to buy more audio gear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote M4trix Quote  Post ReplyReply Direct Link To This Post Posted: 01 July 2020 at 11:42pm
Speaking of which, is any European country making these special heat sinks for amplifiers ?
Or does someone here have these lying around and wants to get rid of them ? Of course,
bare heat sinks without the PCB and stuff.  Smile
Edit: Preferable 3U height
Edited by M4trix - 02 July 2020 at 10:00pm
Post Options Post Options   Thanks (1) Thanks(1)   Quote Earplug Quote  Post ReplyReply Direct Link To This Post Posted: 02 July 2020 at 9:42am
I have plenty of heatsinks lying around, a couple - or more - similar to what you have posted. How many do you need?   Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote M4trix Quote  Post ReplyReply Direct Link To This Post Posted: 02 July 2020 at 1:40pm
@Earplug, check your inbox. Smile
Edited by M4trix - 02 July 2020 at 2:18pm
