Amp Internals 2 |
Post Reply | Page <1 235236237238239 260> |
Bams
Well in the end somebody had to divide by Zero ;)
M4trix
Well, there's nothing interesting to see out there anymore. No old skool amps, just...hmm...something that looks like PC hardware. 1U/5kW ? Meh...
Earplug
Here ya go - posted this a few days ago in another thread - a couple of spare Crest 7001 modules. You can't get much more old skool than these! |
kedwardsleisure
Haven't posted in a while so thought I'd take a snapshot of a brace of Labs that came in this week. Not sure if this was covid-related.
North Staffordshire |
jbl_man
Properly on-fire that one. Is it repairable Kevin?
kedwardsleisure
Done!
djeddie
That's bloomin' impressive. Almost PSL'esque! ;-)
JonB67
You must be an upper order magic smoke wizard if you managed to get the smoke back into that one.
M4trix
kedwardsleisure
I'm sure the intact fuses and the ones missing from the adjacent (good) channel had something to do with it. It blew up - let's blow it up some more!
Earplug
A friend dropped these beauties off yesterday for general clean up and renovation. They actually fired up and worked, which was quite amazing. Don't do 2 ohm bass - but will do 500 ohm stacks! The smaller one still has original (and very rare) EL506 on the output, which I will change for the 7868 equivalent. One of the smaller valves was also dodgy, so will change them all. Even so, it sounded really good - which was not so with the other. It was distorting early, so will definitely need a complete valve change - and then see where we are. In any case, to be filed under "They Definitely Don't Make Them Like This Any More"!! |
Sonic the hedge
Registered User Joined: 12 May 2020 Status: Offline Points: 161 |
DC doesn't go through transformers? Still a very odd way to do DC protection because a relay is surely cheaper. As its class B O/P I guess the transformer will also smooth out any crossover distortion, but that doesn't say much for the design!
Edited by Sonic the hedge - 09 June 2021 at 4:23pm |
