Amp Internals 2 |
Post Reply | Page <1 202203204205206 260> |
Dub Specialist Sound
as we kno bro, few and far between, most soundman wont let them go too
soundsystem history
nickyburnell
I love old stuff like this. Give us more. From a time where it wasn't built to a price, just to do a job........forever
kedwardsleisure
Crown LPS2500. It's come to this, has it, Crown.
North Staffordshire |
JR.junior
OMFG!!
A Phonic Transformer???
On a brighter note, I picked up a used Crown XS 900 for £91.00 on eBay. Took the time to give it a thorugh bench test in terms of output voltage yesterday and recieved the following numbers: Rated Power: 900 watts per channel @ 1 kHz, under a 4 ohm load Measured Results before Clipping Takes Place 20.707 kHz, 72.1 volts, 4 ohm load: 1299.60 watts 14.991 kHz, 64.0 volts, 4 ohm load: 1024.00 watts 10.004 kHz, 64.0 volts, 4 ohm load: 1024.00 watts 5.003 kHz, 64.0 volts, 4 ohm load: 1024.00 watts 2.083 kHz, 64.0 volts, 4 ohm load: 1024.00 watts 999.282 Hz, 64.0 volts, 4 ohm load: 1024.00 watts 500.995 Hz, 64.0 volts, 4 ohm load: 1024.00 watts 200.939 Hz, 64.0 volts, 4 ohm load: 1024.00 watts 100.882 Hz, 62.9 volts, 4 ohm load: 989.10 watts 50.221 Hz, 62.5 volts, 4 ohm load: 976.56 watts 39.903 Hz, 62.0 volts, 4 ohm load: 961.00 watts 30.021 Hz, 62.9 volts, 4 ohm load: 989.10 watts 20.746 Hz, 62.2 volts, 4 ohm load: 967.21 watts 9.999 Hz, 62.2 volts, 4 ohm load: 967.21 watts 4.939 Hz, 60.0 volts, 4 ohm load: 900.00 watts (Amplifier goes into DC Protect beyond 60 volts) Unfortunately, I did not have Allan Wrench small enough to remove the top cover completely so, I had to use my phone to see what was inside. Best Regards, Edited by Elliot Thompson - 03 February 2017 at 4:31pm |
nickyburnell
Trying to compete with the Thomann, Berry world, something has to give.
Why buy new had these for £179 quid at one stage PS. Never had anything Phonic go wrong personally, not even an MRT60. |
kedwardsleisure
well this one's gone wrong.
Crown have used rebadged Phonics for some time now at the lower end and the bigger XLS models |
It makes one wonder why would someone invest in the XLS offering a Phonic Transformer and not just buy a Phonic Amplifier with equal amount of output power at a lower price point? Best Regards, |
taurusty
To know is the greatest. Do You ask sellers to open units that you're interested
In?
I don't buy anything used that I have not done my research on. I will take the chance if the price of the item so low I can afford the loss for, I can always use it for parts. There is just so much information on the Internet today one should not buy anything used without conducting their own research. Best Regards, Edited by Elliot Thompson - 03 February 2017 at 5:20pm |
nickyburnell
Funnily enough I have had Crowns go wrong |
Earplug
Like some Peavey/Crest amps. The Crest badge will cost you more than the equivalent Peavey. |
