Extended CB-18 Cyclops |
Post Reply | Page <1234 17> |
streetsounds
Registered User Joined: 12 July 2008 Location: Santa Rita Status: Offline Points: 301 |
Wait. Ill figure out how to post the plans.. |
Bass matters...
streetsounds
Getting coated with fiber matting and polyurethane
Some more sanding and do the final coating including the aluminum corners. Edited by streetsounds - 12 November 2010 at 1:05am |
Bass matters...
Ibex
Young Croc Joined: 27 May 2009 Status: Offline Points: 1013 |
Good job, mate! What are those cabs behind? SB-18 or half MTL-1X? |
Teunos
Looks good. I did spot you fibreglassed over the nut-holes for the driver attachment didn't you.
At least you know it will last forever now you've fibreglassed id. Just wondering if you'll be putting a grill on? |
Best regards,
Teun. |
streetsounds
Yep fiberglass over the bolt holes but just poke it and there will be hole again. Ill put screen on it but just by the square opening, and then put also a detachable board (via twist lock) with 4 wheels on it.
Bass matters...
streetsounds
@ Ibex: They are modified T-18 they called it here Sub-scoop, deeper but narrower than T-18
Bass matters...
streetsounds
Finally completed 2 of the 6 Cyclops Im building, these two will be on their first job tomorrow.
Bass matters...
SBC
Registered User Joined: 25 November 2010 Status: Offline Points: 1266 |
love the grill and wheel board arrangement!
what made you decide to fibreglass over them, was it necessary?
F.T.S.S.
streetsounds
Thanks..To make it more tougher against bumps and scratches, its common here in my place that diy speaker bins are coated with fiber glass. |
Bass matters...
Speaker Sol
Young Croc Joined: 15 September 2009 Location: Ireland Status: Offline Points: 1320 |
streetsounds
I could not able to put the volume to normal level, neighbors ang complaining about the bass
Edited by streetsounds - 01 December 2010 at 1:50pm |
Bass matters...
staiper
Registered User Joined: 26 February 2004 Location: Croatia Status: Offline Points: 545 |
mmmmmm , looks serious, compact rig, very tough and pro.
What is sound "feeling" in front of 3 CBe-18 stack? |
Just do it! ..or do not.. ;)
