Extended CB-18 Cyclops |
Post Reply | Page <1 910111213 17> |
streetsounds
Registered User Joined: 12 July 2008 Location: Santa Rita Status: Offline Points: 301 |
give me your email add and i send it to you |
Bass matters...
streetsounds
i think i need to convert the plan first to jpeg to paste it here
Edited by streetsounds - 23 December 2011 at 7:17am |
Bass matters...
streetsounds
Edited by streetsounds - 23 December 2011 at 7:21am |
Bass matters...
Julius I
New Member Joined: 01 May 2011 Location: Catalunya Status: Offline Points: 7 |
My email is juliussound@aol.com
Thank you very much. Julius Noguera |
chrispadi
New Member Joined: 03 January 2012 Status: Offline Points: 2 |
hello streetsounds,
tried downloading CBe-18 file on page 3 but link is dead, could you please send me too a copy? my email is: chris_padi@yahoo.com thanks much in advance. |
rhodrich
New Member Joined: 26 August 2009 Status: Offline Points: 2 |
@streetsound sir hows the performance of the cyclops compired to w subs or wsx. i used a diy wsx sub but im not so satisfied the out come its more on mid base. i comepare 6 pcs wsx and 6 pcs w sub the w it more loader. please reply thanks |
Centauri
Old Croc Joined: 29 November 2004 Location: Newcastle Aus Status: Offline Points: 1792 |
Your DIY WSXs must have either the wrong sort of driver or some other build issue - a stack of six genuine WSX is VERY satisfying, and should easily outrun a stack of six CB-18. Conversely, one or two CB-18 should outdo one or two WSX - a matter of the right tools for the particular situation.
Teunos
Just re-read the entire thread, since i'm also thinking of covering my th with fibreglass, and i must say this is one of the strangest things i to have noticed. Walking round the back of the cab and it's like they are not even switched on. Stuffed a club with some th 2 weeks back and before this the owners were always complaining about the killing amount of bass on stage (directly behind the BR subs) and lack of it in the audience. Placed the th at the exact same location the BR cabs normally are, almost no bass at all on stage and way more in the audience, very happy club owner.
Best regards,
Teun. |
geoSal
Registered User Joined: 05 July 2011 Location: THESSALONIKI Status: Offline Points: 338 |
is it worth replacing my old x1 's v18-1000 loaded with cbx-18?
it is a 4 way system (8 x1,8hd15,4mt102) x1's are tuned 34-75hz clearly sub duties |
Teunos
CB-18x won't do 35Hz
Best regards,
Teun. |
peterluc0629
New Member Joined: 07 June 2011 Location: philippines Status: Offline Points: 1 |
comparison for cb-18 cyclops to 1850. any idea?
rhodrich
actualy i have 18 wsx but im not satisfied so much the out come. mybe how i cut the cross-over. looks like the cyclops are good and much easy to build.
