  New Posts New Posts RSS Feed - Extended CB-18 Cyclops
 Post Reply Post Reply Page  <1 1314151617>
tv00 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tv00 Quote  Post ReplyReply Direct Link To This Post Posted: 22 September 2016 at 12:16pm
Why would you set the highpass higher when you use more?
People say that a stack drops deeper than a single, I know that this is not normally the case with tapped horns, only FLH, but people seems to agree that this is the case...
parabox View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote parabox Quote  Post ReplyReply Direct Link To This Post Posted: 05 February 2017 at 5:28am
sorry to revive a   thread but what drivers would you reccomend in the extended cyclops
nickyburnell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickyburnell Quote  Post ReplyReply Direct Link To This Post Posted: 05 February 2017 at 9:55am
Fane Prime
rish View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rish Quote  Post ReplyReply Direct Link To This Post Posted: 05 February 2017 at 10:28am
Rcf LF18x401. Beautiful driver
Rish
cookie-dj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cookie-dj Quote  Post ReplyReply Direct Link To This Post Posted: 05 February 2017 at 10:43am
Would Oberton 18XB700 fare well? Looking to replace my MS46 mini scoops XB700 loaded with these. These seem to do exactly what I need and stack perfectly in height in 3 boxes.
Anyone Midlands based own any?
You can't polish a turd!
tv00 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tv00 Quote  Post ReplyReply Direct Link To This Post Posted: 05 February 2017 at 1:17pm
You should definately do a simulation, I get THE BEST results with rtm "red I" (Royal turbomax) Sims GREAT in there, quite a bit more LF!
@RCF: 18X401 beatiful? -Now look at 18X451, now THAT's beatiful, much better driver for horns / scoops etc, at only a little cost extra, X401 is more of a BR driver in comparison.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickyburnell Quote  Post ReplyReply Direct Link To This Post Posted: 05 February 2017 at 2:15pm
That Red I  has the potential to make a lot of cabs do the business be thinks. Needs a larger mounting hole but would love to try in X1, T18, Cyclops
tv00 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tv00 Quote  Post ReplyReply Direct Link To This Post Posted: 05 February 2017 at 2:40pm
I do have a simulation comparison of fane 18-1500 & RED I, I can post it
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickyburnell Quote  Post ReplyReply Direct Link To This Post Posted: 05 February 2017 at 2:43pm
Please.   I built Cyclops with Fane Prime and it was bloody lovely
tv00 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tv00 Quote  Post ReplyReply Direct Link To This Post Posted: 05 February 2017 at 7:00pm
I'm glad to hear that!
I did a sim of prime, which wasn't as good as 18-1500s or RED I, but I need to get my 18-1500s swapped for something some day and I have acces to xs :-)
I'll just take a dive in the old hornresp folders...
tv00 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tv00 Quote  Post ReplyReply Direct Link To This Post Posted: 05 February 2017 at 7:18pm
Here u go, RED I has the flattest curve, "PRIME" XS doesn't go as deep according to hornresp:-(
XS VS RED I (first in black)
Fane 18-1500 VS. XS:
RED I vs. 18-1500:
XS vs LF18X451:
Th-th-th-tha-tha-tha-that's all, folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickyburnell Quote  Post ReplyReply Direct Link To This Post Posted: 05 February 2017 at 8:43pm
Should add the one I did was not extended version
