  New Posts New Posts RSS Feed - Have someone tried this?
tobiazz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tobiazz Quote  Post ReplyReply Direct Link To This Post Topic: Have someone tried this?
    Posted: 05 December 2010 at 6:28pm
Hey guys
Just had a thought or two.
Have enyone tried to sim a 12" version of the CB-18?
I meen, could this be a small killer box?
And then the 12" MTH-30 which a have heard my self (cracy bass from one 12")
Have some one tried a 18" or 15" version? to have the same greate bas, but whit more power and cabebel of going deeper?
Cheers :)
(sorry for my bad english :))
subbass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote subbass Quote  Post ReplyReply Direct Link To This Post Posted: 05 December 2010 at 6:32pm
Originally posted by tobiazz tobiazz wrote:
Hey guys
Cheers :)
the tapped horn on here (15") goes 3db louder, and has 12hz more bass extension Wink (-3db at 40hz, as opposed to 52hz with the mth-30)
edit: the plan may be a few pages back :)
Edited by subbass - 05 December 2010 at 6:33pm
JDCutta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JDCutta Quote  Post ReplyReply Direct Link To This Post Posted: 05 December 2010 at 6:57pm
also If you google Jbells Tapped (Diyaudio.com) horn has some good tapped horn designs for the eminence 3015lf
http://www.diyaudio.com/forums/subwoofers/127908-jbells-set-four-tapped-horns.html
Edited by JDCutta - 05 December 2010 at 6:58pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote JDCutta Quote  Post ReplyReply Direct Link To This Post Posted: 05 December 2010 at 6:59pm
A 12" or 15" version of the cyclops would be cool though :)
mikey bear View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mikey bear Quote  Post ReplyReply Direct Link To This Post Posted: 05 December 2010 at 9:37pm
and only 130mm taller.
Post Options Post Options   Thanks (0) Thanks(0)   Quote subbass Quote  Post ReplyReply Direct Link To This Post Posted: 05 December 2010 at 10:16pm
yes, overall size of MTH30 is 127L, THAM15 is 187, so 60L difference.
there are many other tapped horn designs over on diyaudio.com in their subwoofer section - depends on your exact requirements
i remember seeing one that in a group of 4 did 140db at 30hz, pretty impressive (18" tapped horn)
login4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote login4 Quote  Post ReplyReply Direct Link To This Post Posted: 06 December 2010 at 12:14am
can you find a link to that im interested Wink
CELTIC SUBSONIC SOUND SYSTEMS
Post Options Post Options   Thanks (0) Thanks(0)   Quote subbass Quote  Post ReplyReply Direct Link To This Post Posted: 06 December 2010 at 12:28am
should be this one
Edited by subbass - 06 December 2010 at 12:32am
Post Options Post Options   Thanks (0) Thanks(0)   Quote tobiazz Quote  Post ReplyReply Direct Link To This Post Posted: 06 December 2010 at 7:28pm
Hey guys
Cheers :)
Wow That looks like a nice littel sub :)
But it uses a quit expencive driver, could it be used whit e.g. this:
http://www.thomann.de/dk/fane_sovereign_pro_15_600_lf.htm
Also that 18" FT30 is pretty insane!
Still a 12" "CB-18" would bee nice :)
