  New Posts New Posts RSS Feed - 1850 build query
1850 build query
Vulkan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Vulkan Quote  Post ReplyReply Direct Link To This Post Topic: 1850 build query
    Posted: 23 January 2011 at 9:04pm
I'm currently in the process of biulding a couple of 1850 cabs. I realise the PD1850 is the best suited driver... but its a bit out of my budget. I've heard the Void V18 1000 driver works quite well in this desgin, am i correct in thinking this? Does anyone know of a distributer where i can get my hands on this driver?
Or can anyone recomend another driver that works well in this cab? (budget of about 200 pounds per driver)
I'll get pics of the build up soon and im sure i'll have more questions as things move on...
Father-Francis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Father-Francis Quote  Post ReplyReply Direct Link To This Post Posted: 23 January 2011 at 9:11pm
Void Acoustics LTD UK
Unit 10b Dawkins Road Ind Est
Poole , Dorset, BH15 4JD
United Kingdom
Tel: +44 (0)844 410 1440
Fax:+44 (0)844 410 1439
e-mail: web@voidaudio.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Vulkan Quote  Post ReplyReply Direct Link To This Post Posted: 23 January 2011 at 9:43pm
Nice one, will give them a call
adyk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote adyk Quote  Post ReplyReply Direct Link To This Post Posted: 23 January 2011 at 10:04pm
http://www.bluearan.co.uk/index.php?id=VODV181000
This where ive got 4 from, hope this helps.
Edited by adyk - 23 January 2011 at 10:05pm
Bryan M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bryan M Quote  Post ReplyReply Direct Link To This Post Posted: 26 January 2011 at 11:58pm
They are out of stock on v1000 i've been told, next delivery is in two weeks. Sounds like a lot of people asked for them for christmas....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Vulkan Quote  Post ReplyReply Direct Link To This Post Posted: 27 January 2011 at 1:02pm
yea, thats why i was asking, i saw that they have a load on order, but had no idea how long that would take. are there no other distibuters around?
also, when cutting the mitres for the wood, i'm having a bit of trouble working out how to cut the really sharp angles, as my saw only goes to 45 degrees... how did others get by this problem? any little tricks to share?
chopper27 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chopper27 Quote  Post ReplyReply Direct Link To This Post Posted: 27 January 2011 at 5:10pm
you can tap packers on the saw base
Post Options Post Options   Thanks (0) Thanks(0)   Quote Vulkan Quote  Post ReplyReply Direct Link To This Post Posted: 27 January 2011 at 10:47pm
yea , we ended up running one side of the saw base along a strip of wood and after one mistake it turned out pretty good. fairly happy woth how its all coming along atm
moyano View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote moyano Quote  Post ReplyReply Direct Link To This Post Posted: 26 February 2011 at 9:19am
second hand pd1850's !
