  New Posts New Posts RSS Feed - martinson tham 15
martinson tham 15
 Post Reply Post Reply Page  <1 4567>
Keen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keen Quote  Post ReplyReply Direct Link To This Post Posted: 12 July 2018 at 3:42am
if you're building 12, why do you need 4 ohm drivers?
Angelow View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Angelow Quote  Post ReplyReply Direct Link To This Post Posted: 12 July 2018 at 11:01am
thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Angelow Quote  Post ReplyReply Direct Link To This Post Posted: 12 July 2018 at 11:02am
[QUOTE = Keen] se stai costruendo 12, perché hai bisogno di 4 driver ohm?
6 x side work @ 2,66 ohm
[/CITAZIONE]
Post Options Post Options   Thanks (0) Thanks(0)   Quote Angelow Quote  Post ReplyReply Direct Link To This Post Posted: 13 July 2018 at 3:37pm
Originally posted by MagicJohansson MagicJohansson wrote:
35 Hz
12db buttherworth?
but at the end you have mounted 4 dflectors?
or the numbers 1 2 3 4?
so like this without cutting the front panel?
or was everything as in this picture?
Edited by Angelow - 13 July 2018 at 3:37pm
MagicJohansson View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote MagicJohansson Quote  Post ReplyReply Direct Link To This Post Posted: 13 July 2018 at 5:17pm
On the first box we installed all 1, 2, ,3, 4 and 5 but on the second only 1 and 2 and You can not tell any difference in sound. The deflectors do make the box more rigid but even without them its is like a tank.
The high pass is a 24db Linkwitz Riley, the lowpass 12dB LR .
I thought about cutting the front top panel as in the middle picture but I don't think it would make any difference in the sound and would only make attaching the front steel mesh more difficult.
AngusR9090 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote AngusR9090 Quote  Post ReplyReply Direct Link To This Post Posted: 13 July 2018 at 5:43pm
Ye is a proper mega strong box.
I think you could easily get away with a 15mm ply or even 12mm ply version with extra bracing.
When I was young.... we still had parties
Post Options Post Options   Thanks (0) Thanks(0)   Quote Angelow Quote  Post ReplyReply Direct Link To This Post Posted: 14 July 2018 at 9:28am
I was doing the mk2 because I read it works better with 4 cabinets put together:
I wondered, the panels of the baffles in the blog post are 45 ° while in the rendering they seem different ..
What is the correct way to mount them?
even the deflectors at the top seem to have different angles from the right angle
Edited by Angelow - 14 July 2018 at 9:55am
tthorsten View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tthorsten Quote  Post ReplyReply Direct Link To This Post Posted: 16 July 2018 at 2:47pm
what happens if i have other dimensions on the outside and only 15mm MPX
i want to build them with 50x70cm and 55-60cm deep.
www.tb-audio.de
LEVELchek www.levelcheck.de
SPL tracking
SATlive www.satlive.audio
best Measurementsoftware for Live People
DBlimits
www.dblimits.com
Isemcon EMX7510 measurment Microphon
Andylaser View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andylaser Quote  Post ReplyReply Direct Link To This Post Posted: 24 November 2020 at 8:31pm
Any thoughts on building a pair of these using RCF LF15G401?
"music so loud, that if we move in next door to you; your lawn will die" - Lemmy
fatfreddiescat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fatfreddiescat Quote  Post ReplyReply Direct Link To This Post Posted: 24 November 2020 at 8:47pm
Should work just fine, very similar specs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fatfreddiescat Quote  Post ReplyReply Direct Link To This Post Posted: 24 November 2020 at 8:48pm
PS you heard anything form Southwest CNC? think he was based down your way and was making up some good THAM15's at a decent price.
concept-10 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote concept-10 Quote  Post ReplyReply Direct Link To This Post Posted: 24 November 2020 at 9:15pm
He went bust, a few of his customers have come to us, very unhappy people.
This page was generated in 0.422 seconds.
