  New Posts New Posts RSS Feed - new 18k B&C rig requiring amps
solomon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote solomon Quote  Post ReplyReply Direct Link To This Post Topic: new 18k B&C rig requiring amps
    Posted: 05 September 2004 at 11:08am
Hi guys
ive recently aqquired an 18k system,  It comprises of the following six of 2 x 18” sub bass units , and ten of the mid/top speakers which are loaded with 2 x 10” drivers + 2” HF unit, It is all loaded with high quality B&C components, i need the correct amps to run these beautys......... could you please point me to ideal amps?????
SYSTEM SPEC
2 X 10” + HORN MID/TOP CABINETS
Wide-bandwidth system
Multi-angle birch ply enclosure
90º x 60º horn
Top hat fitting for tripod mounting
2”compression driver
TECHNICAL SPECIFICATIONS
TYPE
Compact, two-way passive, multi-angled, vented
FREQUENCY RESPONSE
55Hz-18kHz ± 3dB
DRIVERS
2 x 10” Mid/ bass drivers
2” exit compression driver
RATED POWER
700W AES, 2800W peak
RECOMMENDED AMPLIFIER
400-1600W into 4 ohms
SENSITIVITY
103dB
MAXIMUM SPL
129dB continuous, 137dB peak
IMPEDANCE
8 ohms nominal
DISPERSION (-6dB)
80° H x 50° V
CROSSOVER
1.2kHz passive
ENCLOSURE
68 litre, multi-laminate birch ply
FINISH
Textured blue paint
PROTECTIVE GRILLE
Black perforated steel WITH Black Acoustic foam
CONNECTORS
2 x Neutrik NL4
FITTINGS
Top hat fitting
2 Bar type carrying handles
DIMENSIONS
(W) 471mm x (H) 690mm x (D) 443mm
WEIGHT
32.5kg
2 X 18” SUB BASS
Direct radiating 18” (460mm) drivers
High temperature 4” (100mm) voice coil
Fitted with handles and castors
TYPE
Dual-driver vented sub-bass system
FREQUENCY RESPONSE
35Hz-150Hz ± 3dB
DRIVERS
2 x 18" (460mm)
RATED POWER
2000W AES, 4000W peak
800-3000W into 4 ohms
SENSITIVITY
104dB
MAXIMUM SPL
133dB continuous, 142dB peak
IMPEDANCE
4 ohms nominal
DISPERSION (-6dB)
CROSSOVER
150Hz active
ENCLOSURE
320 litre, multi-laminate birch ply
FINISH
Textured blue  paint
PROTECTIVE GRILLE
CONNECTORS
2 x Neutrik NL4
FITTINGS
4 x 4" (100mm) castors
DIMENSIONS
(W) 561mm x (H) 1066mm x (D) 780mm
Bryan M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bryan M Quote  Post ReplyReply Direct Link To This Post Posted: 05 September 2004 at 12:22pm
Speak to alex at pro audio parts and get some of the new void infinite range, sooooooo much power!!! not very expensive either. New infinite 8 = less than a second hand crown. sound good too
loophole View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote loophole Quote  Post ReplyReply Direct Link To This Post Posted: 06 September 2004 at 12:05am
i wasn't fully convinced until the carnival.
yep
