Wharfedale pro 15" LX driver problems |
Groovemeister
Registered User Joined: 02 June 2011 Location: Bedford Status: Offline Points: 33 |
Posted: 13 July 2011 at 9:28am |
Was wondering if anyone knows what the drive unit is in the wharfedale pro 15" LXE.
I would want to improve it if I could so before I take it apart I would like to look at some alternatives possibly?
Adam_Iron_Horse
Old Croc Joined: 02 January 2010 Location: Scotland Status: Offline Points: 2043 |
Thanks(1)
I believe its wharfedales own brand of speakers
Groovemeister
I suppose i should ask if something like a P-Audio SN2-15LF8 would work as a replacement ?
The cabs themselves are great (the plywood ones) so I am sure you could make a really fantastic pair of cabs by upgrading a bit ?
As I have a 3 way crossover I suppose I could always take out the internal crossover and split the mid and top as an option.
Any other ideas ?
Adam_Iron_Horse
Ye probably better asking things like that although the only way to find out is to work out the volume and size of the ports and try different drivers in it on winISD or something similair.
Never knew wharfedale ever made plywood cabs glad to hear as the ones iv seen have all been chipboard which is quite dissapointing tbh... Taking out the internal crossover might be an idea but you would then have to run four core cable and have seperate amps though although for the extra control over the cabinet you might feel its worth it. I always found the high frequency in the wharfedale iv come across more of a problem than the mids tbh so I would be inclined to upgrade the compression driver first |
Groovemeister
Found out it wasn't the driver but something loose in the panel back or the crossover.
I haven't completey diagnosed it yet but I know from moving the speaker about it stops rattling.
I know that it could be a pice of crap in the voice coil gap but I am pretty certain it is not that. I can feel whatever is loose is knocking at the back of the cabinet. Going to tak it apart in the next couple of day's to take a look.
