DIY Dance stack |
Post Reply | Page 123> |
nomercy82
Registered User Joined: 06 April 2011 Location: Pittsburgh PA Status: Offline Points: 265 |
Posted: 21 September 2011 at 7:08pm |
From the plans available on the internet. Which would make the best Dance stack? (Large visually imposing stack of speakers) I was thinking 2 G subs per stack with a barn door extension, and either a dual X215 ( an X 15 extended to fit 2 15's inside it) And Some sort of constant directitivity horns array. All Active.
I was talking to an engineer I know and he chewed me out over wanting to build a system out of old stuff like the EAW BH882 and JBL 2395. I like it but apparently it's not good stuff. |
Building a system in Pennsylvania.
SamV
Old Croc Joined: 21 October 2008 Location: London Status: Offline Points: 8711 |
1850s, HD15s, xtros. Yes there's overlap but it would be imposing.
colint
Old Croc Joined: 06 October 2007 Location: United Kingdom Status: Offline Points: 5227 |
This is what you want! that's what I call imposing
Edit: A Wattco system from Mykey
Edited by colint - 23 September 2011 at 2:38pm |
thepersonunknown
Old Croc Joined: 25 November 2009 Location: Madrid Status: Offline Points: 1628 |
i think labs realy do look bad boy as a lump of bass, i gues you could almost streatch em to xtros, although better and more imposing with usb es 18 between. anyone actualy run a rig like that? not herd this combo exactly myself
They keep telling me life is short, but its the longest thing ive ever done!!!
infrasound
pssst, no way Sam. Only if you like 100hz!
You'd want some badboy FLH / BP6 between 20-80hz - to get some height (Tops need to go OVER peoples heads, not straight at the poor person in front of it). Think 18"/21". Straight hornloaded 15"s, either ported or sealed chamber. 80-240hz. Think impulse response for fast bass. Hornloaded 10" 240hz-2hz to 1.5" / 1" compression drivers. With a sprinking of bullets on top for the cats in the audience. .. Maybe?
infrasound
Or cross between mid/bass and mid higher to 400hz to get a sweeter 8" in the mid horn
nomercy82
Reflex cabs I should have specified. 1850's are too much for ANYTHING I do.
Timebomb
Punisher dance stack... |
shagnasty
12 TSW-121s, 8 TSE-218s, 4 TMS-3 V2 anything else just looks and bit, well, small, quiet and with 4 x PL 9.0 1x PL 6.0 and 2 x PL 2.0 driving it 5 way really made some rather nice sounds, the fact the whole lot looked like it may have anal sex with your Gran, if it wanted just adds to the fun...
nomercy82
Punisher Dance Stack. VERY nice work, is that a Funktion one unit on the very top? and what are the two boxes in the middle?
I think the Turbo sound stack costs more than my car. |
infrasound
Nice Timebomb. Think I've seen those kick sections before on a rig, with tiny, tiny tops above it.
Timebomb
Thanks guys, yep the mid highs are a funktion ax88 split in half, im working on my own mid high but its some way off yet. The low mids are my own design 2 x 12" horn the same external dimensions as a punisher.
