Cepiar Amps |
Post Reply | Page <1234> |
Amateur
Registered User Joined: 28 July 2011 Location: Hungary Status: Offline Points: 22 |
Second amp:
Left fan not work, but clean. :) (In fan control 1pcs 7W/820 ohm resistor burned out) From all 8 Aerovox caps 2 or 3 electrolyte flowing out :S MOSFET's 5-5 pair Exicon 10N16 & 10P16 (eq Hitachi 2SK134 & 2SJ49) / channel Edited by Amateur - 29 October 2011 at 9:45pm |
cryz2
Registered User Joined: 10 July 2011 Location: SW LONDON Status: Offline Points: 167 |
solid looking amps
Edited by cryz2 - 29 October 2011 at 1:01pm |
Force one sound system
colint
Old Croc Joined: 06 October 2007 Location: United Kingdom Status: Offline Points: 5227 |
Saw some like these on fleabay, They look very much like the Austin Armstrong/Monitec amps.
cryz2
your 100% right about
Monitech " designed / manufactured" I received a very nice Pm regarding the amps .
colint
Thought as much I had a few myself not so long ago, I sold them to someone on SP but cant remember who, This is one of the smaller amps.
Nice sounding amps but did get a bit on the warm side when pushed.
cryz2
its nice to see this version ,
it would be good to compile photos of all the different ones that are about i see this one has the gains on the front panel rather than the back |
colint
I had a look through my photo's and this was the only one I could find (the other amp's I had all looked the same anyway) They also did some 4 channel amp's that were quite useful. Edit: One thing, never try and run them @ 20hms/4ohm bridge they won't do it and will die quite quickly
Edited by colint - 30 October 2011 at 9:22am |
cryz2
seems to be quit clean inside , it did have some very back dust that i cleaned out , looks like it might have a 2x leaking capacitors , it looks like some black goo has seeped though the glue on the caps nearest the fans , at first i thought some dust had just collected on the glue but it looks like a bit of a leak :/ the amp dose sound nice i had on channel drop out for a few seconds on power up , but seemed to be fine after , i gave the amp a half power test on Channel A and then on B , then a full power test for about an Hour , with out any issues , |
Muckerbarnes1
Old Croc Joined: 20 March 2010 Location: Stroud Status: Offline Points: 2654 |
What age are these Austin Armstrong amps?
They look similar to some amps I was asked to help modify some years back as they had problems, mostly the 4 channel versions. They claimed some affiliation to C audio at that time I believe. They were gutless.
Billy Dawg.
cryz2
The
Cepiar RSC 600 i have , has a 2000 date stamp on one of the board
so sometime after that |
cryz2
very solid construction i am not 100% on what the 3 way stereo switch dose ??? is to the left mono ? to the right bridge ? and centre stereo ? dose anyone have any input |
Muckerbarnes1
The Austin Armstrong ones were circa '94 in various power and a 4 channel.
I think the guy was from Cambridge.
Billy Dawg.
