Cepiar Amps |
Post Reply | Page <1234> |
colint
One position is bridged another stereo and the other should be parallel mono if memory serves me right. The best person to speak to about these (or Austin Armstrong or Monitec as they're all the same company) is SP member Monitec I'll leave yo to guess why? I really liked the Monitec and Austin Armstrong amp's, OK they wasn't mega powerful by today's standards but they ran well and had a nice warm sound to them the four channel amp's did have some issues but when you think how long ago they were made they were pretty cutting edge at the time. From memory all the above company's were made up from the staff of C-Audio hence the connection that someone made earlier in the thread.
Muckerbarnes1
Old Croc Joined: 20 March 2010 Location: Stroud Status: Offline Points: 2654 |
So Colin who would the guy have been that wanted to sell us amps in the early 90's as Austin Armstrong, then came into our workshop where I was putting our amps together.
We did some A/B bench tests. He then wanted me to go to Cambridge to do mods to their amps to try an acheive comparable results. The last I heard he was no longer with us?? But cannot confirm this. We did use some 4x500 ones for mids, then modified them. Great days.............
Billy Dawg.
colint
I can't remember to be honest (think it may have been Dave Collins) but I know he came into our shop with the first 4 channel 500 of the line and I nicked it of him to "road test" it he never did get it back
That was to only one we ever had but we did use a few of the two channel amp's in install's without any problems and I believe Tonyass used to run part of his rig on them at one point and as well as Monitec (Richard) Tony is/was (Dave is no longer with us) good friends with both Richard & Dave Collins.
Muckerbarnes1
Thats it. Dave Collins. There was at that time a claim he was the C of C audio??? Don't know. A nice guy.
Wanted me to camp out in a hotel and work on his amps. Such a shame he has gone. I think I have some of their schematics here somewhere. They were too complicated. Simple is best. Bit like the comparison of an old PPX Vs a VX.
Billy Dawg.
colint
Yup that's him he was C-audio (and Monitec and Austin Armstrong) C-audio started as Chesterton audio (think he was with MM before that) he sold C-audio started Monitc and then it all changed again to Austin Armstrong, Richard on here was with him most/all of the way nice fella also (runs a very nice ASS rig) I'm sure someone will correct me if I'm wrong with any of this (Getting old so memory not so good these day's)
Amateur
Registered User Joined: 28 July 2011 Location: Hungary Status: Offline Points: 22 |
This is correct. mono or bridge LED lighting when switch mono or bridge position. Leaking caps.... :S |
colint
That'll happen on a amp this old sometimes!
Amateur
Yes, time is time :)
I'm changed leaking caps, and amp works fine. Real test this saturday night. :) |
Devinder1940
New Member Joined: 30 January 2012 Status: Offline Points: 1 |
I have one of these Amps. Has anyone got its full specification please.
chickenfizz
Young Croc Joined: 17 March 2008 Location: United Kingdom Status: Offline Points: 982 |
I have one of these, developed a fault recently, no output on left channel. Just got around to looking at it, high Voltage rails OK on both sides, low voltage rails all OK at regulator outputs, but the op-amps on the input board were floating at around -15v, traced it to a broken track, seemed to have been corroded away... Guess what? Leaking high Voltage filter cap!
And no wonder they've failed, they're 80V 19000uF caps in one channel, and 100v 15000uF in the other! I measured +/- 82V on them which is too much for an 80V capacitor. Both types of capacitor have similar date codes and are by the same manufacturer so I have no doubt that it left the factory this way. Any of these amps with 80V caps need upgrading as they won't last being operated that close to their limit. Getting replacements is not straight-forward either, in fact I've not found any 5 pin 100V caps in the 15000-19000uF range that fit in the space (critically 40mm dia by 105mm length or less). The closest I could find of the right dimensions that was in stock anywhere was 10,000uF which I'm happy to settle for, there's not a lot in it. I was hoping to get 105deg ones too, but no such luck. |
cryz2
Registered User Joined: 10 July 2011 Location: SW LONDON Status: Offline Points: 167 |
HI chickenfizz could you please tell me ware you sourced the your replacement capacitors from
Thank you |
Force one sound system
chickenfizz
Sure, a top secret electronics supplier... R.S. :)
Link to the exact product: http://uk.rs-online.com/web/p/aluminium/2271232/ |
