Glass Fuse/bulb Protection |
Post Reply | Page 123> |
Author | |||||
CHAMPION
Old Croc Joined: 30 September 2004 Location: United Kingdom Status: Offline Points: 3667 |
Posted: 07 December 2011 at 4:00pm |
Whats the point in putting a Quick Blow Glass Fuse on the cross over network of a mid/high speaker when it can not prevent the Compression Diaphragm from shorting out !
Edited by CHAMPION - 07 December 2011 at 4:29pm |
Sticks n Stones
they're bulbs, not fuses.
but you're right, should protect them really...
JohnnyPyro
Old Croc Joined: 17 November 2008 Location: London Status: Offline Points: 2083 |
wrong wattage lamp me thinks .. lamps should blow way before the comp ... had them from new?
Powered by MC2 & XTA |
Herb-i
Registered User Joined: 22 November 2011 Location: Bolton Status: Offline Points: 275 |
Correct fella...........
lgosdset
Young Croc Joined: 28 September 2010 Location: Reading ish Status: Offline Points: 1203 |
they are fuses weather they can be used as a light bulb or not, it performs the same function, as well as very basic limiting. Stop nit picking. fuse
clearly they were not the correct rating. |
chris_k
Young Croc Joined: 14 April 2005 Location: United Kingdom Status: Offline Points: 1258 |
Not a bulb. People in the know call them lamps!
MessyM2k8
Young Croc Joined: 29 October 2008 Location: Norwich Status: Offline Points: 690 |
this, you plant bulbs in the garden, ah how many times have we heard that one? |
chris_k
Whenever I'm in the wholesalers and a member of the public comes in asking for bulbs, one guy behind the counter always says that. Every bloody time.
kedwardsleisure
I think it's an age thing. I call those bulbs and I call decorative table fixtures 'lamps' as in 'standard lamp' or 'bedside lamp'.
But this is well-trodden nonsense. Those limiter lamps are meant to afford limiting. If they blow, you've ridden the limiter once too often. Some manufacturers use fuses, some use bulbs, some use PTC thermistors (polyswitches), some use thermal breakers and some use sweet FA. I don't think they're designed to be fool proof, which is ironic in a way. Yes, I have customers who think they have novel sound-to-light loudspeakers that are actually meant to flash to the bass beat as an attractive feature of their speakers. Honestly. |
North Staffordshire |
Centauri
Old Croc Joined: 29 November 2004 Location: Newcastle Aus Status: Offline Points: 1792 |
Agreed - by the time there is enough voltage to blow the lamp / bulb / illumination device, it has well and truly gone past its limiting capability. By the look of the shattered diaphragms. these boxes have been pushed way past what they were designed to do - simple abuse..... Edited by Centauri - 07 December 2011 at 11:29pm |
ev diaphragms aren't cheap either..
are the bulbs blown? |
