Behringer S16 Cat5 Multi & DCX2496 Ultradrive |
Post Reply | Page 12> |
Soundscape
Registered User Joined: 09 March 2008 Location: United Kingdom Status: Offline Points: 416 |
Posted: 12 February 2012 at 10:24pm |
I tried a search on this subject but didn't find anything relevant so if it has come up before, sorry. Reading through the spec of the X32 it packs in a lot of features but as far as I can tell doesn't include any form of LMS - probably the design brief never allowed or intended this and maybe a 'step too far' as they already produce the Ultradrive.
However, suppose you're a band or PA operator wanting to use a DCX2496 Ultradrive in your FOH rack with one of the above mixers (yes, I'm well aware it's not considered 'pro gear' by many and those who already have BSS or XTA based systems probably won't be interested anyway), it appears to me you could use the 6 returns built into the S16 via the 6 line ins built into the mixers. What do others think? Is this setup perfectly feasible or is there a better solution - preferably still using CAT5 for the returns e.g such as APPSYS offer? Thanks to all Steve |
Phil B
Old Croc Joined: 21 November 2004 Location: Melbourne Status: Offline Points: 2322 |
Depends if you want redundancy?
Normally returns are seperate from FOH desk multis to allow for re-patching and board swapping etc etc. Also the power for the drive comes down the returns not the FOH multi again for redundancy. For small gigs with no changes it would be fine...what you would really need though is an Ultradive that accepts AES50! Maybe that`s in the pipeline? .p. |
Soundscape
I agree that having capacity for redundancy is a wise choice and use a separate returns multi with other setups.
Mind you there was a case some years ago when some 'well meaning' numtie of a stage hand decided to tidy up multicores laid in a venue somewhere by nailing them to the structure...... I can just imagine the look of horror on the PA opo's face when he relaised what had happened Double redundancy needed!! But an updated version of the Ultradrive with AES50 outputs - that would be useful. However, if that's not going to be available for various reasons we come back to using a conventional multicore for returns. The Swiss co. Appsys (http://www.appsys.ch) have some nice kit which I've been considering but there's still the issue of converting analogue - digital and back to analogue which is a tad messy. Steve
shagnasty
With AES-50 you can true rundancy by using HyperMac routers to load balance over several links in case on fails, the truth is CAT-5 isn't very gig friendly and no-one in their right mind would build a CAT5 multi without at least one spare line in it.
AES-50 is a Layer 1 Ethernet protocol, IE it abaides by the electrical spec for Ethernet but use proprietry framing and encapsulation so you can't just slam the wire into a Cisco switch and run a cat-5 down either side of the room, but if you treat a cat-5 'core with the TLC you should treat and anolog core you should be fine.
As for AES-50 > Ultrdrive there is no real point in pumping tens of channels of AES-50 into an LMS-with only 6 outs, an AES-50 <> AES/EBU bridge node is what you need, so you can grab the returns channels you need and shoot them into your Ultradrive, but this kinda kit has been historically VERY expensive, that said as the EtherSound, AES-50 market open up budget kit should become available...
Smiter
Registered User Joined: 21 August 2010 Location: UK Status: Offline Points: 1160 |
You should be able to use matrix outputs to control the speakers - and the outputs of these should have EQ, limiting and HPF / LPF slopes. If it can't do that, then it's not even as capable as an LS9
Phil B
Too right it`s expensive! The Midas Network Bridge is great tool but far too expensive! http://www.midasconsoles.com/dn9650.php?src=pro6 Let`s see if the Bellringers can come up with a cheaper AES50 / AES convertor? .p. |
Soundscape
Thanks for the comments & info.
There's something of a dilemma here as we can see good quality, used analogue gear coming onto the market at reasonable money. But the size and weight of this gear e.g. 24, 32 & 40 ch desks + outboard racks + standard multicores can be an issue for small PA companies and bands: number of people required to setup and operate, size of van/truck required and its associated costs, space available in smaller venues (of which there are fewer, especially pubs that provide live music), setup and takedown times compared to what rates can be charged. The development of various digital products offering more features and importantly, more value, has to be helpful in many ways. I appreciate the pro touring market and larger venues are going to specify industry standard products - that's their choice and no one is likely to argue (much) about using a Midas Network Bridge if the tour can afford it. However, I'm eager to see more budget kit come to market because it will present new opportunities at the lower end of the market and hopefully the successful bands will move up the (food?) chain and then use the best kit available.
chickenfizz
Young Croc Joined: 17 March 2008 Location: United Kingdom Status: Offline Points: 982 |
Pulling this thread up from the dead (maybe appropriately since this desk does actually genuinely appear to be going to ship within the next couple of weeks), the limitation with LS9 and many other 'bodge' generic dsp approaches to loudspeaker management is that they're usually only 12dB/Octave Butterworth slopes, like a typical channel inline hpf, which in my opinion is a poor active crossover, I'd sooner use a very cheap outboard analogue crossover that at least had 4th order filters and hopefully Linkwitz-Riley slopes too. |
kevinmcdonough
Old Croc Joined: 27 June 2005 Location: Glasgow Status: Offline Points: 3749 |
hey
I think I'm a little hungover maybe, am confused by the OP's post. As far as I can understand, your talking about having your LMS with you at the mix position and doing your crossing over there, and then sending the six post-crossover lines down the desk returns to stage/PA? Would it not be easier to have your LMS at the stage with both the PA and the stage ends of the stagebox/multicore? That way you can just feed your stereo out or LRS output into the DCX from the output channels of the stagebox and then the crossover feeds straight into the amps? Both achieve the same thing, but just seems like a lot more hassle to me the first way? Or am I more hungover than I thought and not understanding what you mean? k |
spiffing
Young Croc Joined: 17 August 2006 Location: Bristol Status: Offline Points: 634 |
ceharden
Personally I would just make a multicore with a couple of CAT5 (or whatever is required for the digital multi), 16A power and an 8 way analogue signal cable for the returns from the FOH processor.
Still much lighter than a conventional analogue multicore but gives you a few analogue lines for returns, DMX if necessary. |
shagnasty
Ideally run a 4-line fibre and but media converters in, hypermac will go through a fibre<>copper converters as long as it isn't a switch and 4 line 50micrometer multimode fibre is lighter and tougher than cat5.
But comms, returns and a DMX line all up copper is a good plan, use Canford FSM8 as it is DMX/AES-EBU/RS-485 rated as well as audio and weighs toss all. If you want I can also do some very nice little multipins on it!!!!
