scoop compatible drivers... |
Post Reply | Page <1 1718192021 25> |
Crashpc
Registered User Joined: 26 February 2008 Location: Czech Republic Status: Offline Points: 465 |
Just tried today to push 21DS115-8 at Xmax, and it behaved very well. Fully usable.
tv00
Whow that's funky, in a scoop even? How did it feel? :-) |
Crashpc
No, just free air, and around 12-20Hz.
Felt good. Still did A LOT subsonic rumble, And not much wind friction noises. There is no way I would want to push that speaker in usable range (in the box) to Xmax. It would destroy my house. No pun... |
Tonskulus
Two months ago, I lost my HOG virginity at forrest trance parties. There were 4 of them driven by 16kW of total rms power. Sound quality and SPL was totally insane even for long distances! Time to build my own hog's. I'm looking for budget driver for my first hogscoop(s) , but this is kind of pain.however I have few candidates now: PD184 or 186, PD184C01 18sound 18W1000, 18LW2400 Fane colossus 18XB About the sound what i'm looking for, not too soft/warm and lazy. PD1850 would do the trick, but it's out of budget now so I need to make compromises. Which budget driver is best for max. spl beetween 40-50Hz? Oh btw, friend of mine said he still has my old CerwinVega XL18s, I think this should be tested in hogscoop! It was quite brutal in std reflex box too. Lots of punch. parameters: 100db/1w, FS 28Hz, Qts 0.17, Qes 0.18, Qms 5.25, vas 273, BL 31.8, Xmax lin 8.5mm. |
love2all
Registered User Joined: 30 October 2015 Location: london Status: Offline Points: 131 |
Tomorrow i will be testing some rcflf18x451 in some scoops....seen this driver mentioned in earlier pages...has anyone else tried them? Wondering what amp is going to get the best out of them as have previously been using pds on a 5k monoblock....got a feeling the 5k mono block not going to be enough for these!
Tonskulus
Well, I prefer class AB amplifiers w/ big damping factor for best possible cone control (some old QSC amps are really good!). No experience about class-H, I have been told those might have some problems/drawbacks in some circumstanses.
So I'll stick with heavyduty AB for smaller rigs <10kW. Class-D for larger systems. Edited by Tonskulus - 16 September 2017 at 8:57am |
Crashpc
Tonskulus: Everything has its drawbacks and shortcomings. I think that moct Clas-H amps have different problems than the class itself.
Also, Things like FP10000 or FP14000 (Lab Gruppen and its copies) have very clever power stage and output stage. It basically can be AB class with ~90% efficiency, due to the power supply delivering exactly needed voltage for the waveform going trough at the moment. So while the power supply output can copy the signal waveform + some reserve, the output stage doesn´t have to face the huge voltage drop needed for conventional AB amp. "SMPS-D-class approach" gets its use, and oldschool guys with AB class in their head are satisfied too. |
Sypa
Try oberton 18xb1500 , exactly what you want. Even tighter sound compared to 1850 and spl monster if coupled to a nice amp.
And the price is ok Edited by Sypa - 16 September 2017 at 6:54pm |
Crashpc
That looks like one very nice driver, indeed! And price is also quite good.
But will propably need also some additional processing and non-conventional design if used in bassreflex box. |
Sypa
Oh sorry forgot to add for hogs
tv00
I tried it and I liked it, these are BRUTAL in a scoop :-) But I didn't do any A/B comparisons, so the room (club) affects my experience. To me it was clean, deep & headroom far above where we could go. I know people also using these in TH and happy about it (which I wouldn't expect to be the best) These drivers are really good power for the money, I think I'd take these over Obertons any day. Only thing is that RCF are crazy, lead times for kits are ½ a year :-( |
MarjanM
Lead time for what kit? Recone kits? That can not be that long. Friend of mine distributed RCF here and everything comes within 6-7 weeks.
